What's the scenario that we use 1 IP address for both switched ports?
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • What's the scenario that we use 1 IP address for both switched ports?
Romain_Polette
Kirk Romain_Polette Kirk
117
Guillaume_Evrard
59
Randi_Dolan
46
QuanGUO
Lieutenant QuanGUO Lieutenant
Lieutenant
Posted: ‎2014-08-10 07:48 AM
1071
I'm curious what the scenario we may use 1 IP address for both switched ports? The goal is for Ethernet ports Hot/Standby redundancy or Ethernet ports cascading for easy wiring?
Some gateways or devices have two Ethernet ports to make network wiring easier. Dual Ethernet ports allow users to string multiple gateways together using standard RJ45 Ethernet cables, eliminating the need for a separate Ethernet switch.
4330
Quan
Tags (2)
  • dual
  • ports
JamesJeanette
Commander JamesJeanette Commander
Commander
Posted: ‎2014-08-11 06:31 AM
1
998
Here is the Ethernet Port settings section from the Com'X 200 1.1 User Guide: (Pages 55-57).
Screenshot:
4327
Let me know if this helps for the Com'X uses.
JamesJeanette
Commander
1
999
Screenshot:
4327
JamesAZZO
Sisko | EcoXpert Master JamesAZZO Sisko | EcoXpert Master
Posted: ‎2016-02-09 08:35 PM
James Jeanette - I think this answers my question, but essentially, can we Ethernet Daisy Chain Com'Xs? The diagram in Switch mode seems to show you can have both Ethernet port the same in IP world, but not necessarily that they are acting like an unmanaged switch for all traffic pass through. It's like the Com'X can read it on both sides, but are does it pass the packets through to the other side?  The name indicates it but it would be good to show multiple Com'Xs in the diagram (like Quan has above to be sure they can all be put onto the same network switch with one Ethernet Daisy Chain.
Can you just confirm this is true?
