Updating PAS Firmware on 3/4G router(slow network) via remote VPN login
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • Updating PAS Firmware on 3/4G router(slow network) via remote VPN login
Romain_Polette
Kirk Romain_Polette Kirk
117
Guillaume_Evrard
59
Randi_Dolan
46
EcoStruxure Panel Server Universal
wasabi
Lieutenant JG wasabi Lieutenant JG
Lieutenant JG
Posted: ‎2023-12-04 05:13 PM
1225
Hi team,
I have a question about updating the PAS to the latest firmware via VPN remote access.
We have a few PAS600 deployed with a 3-4G router connected and I can connect to them via OpenVPN and using remote access via SE portal. However, it is slow in uploading the file and times out.. is there another method to upload .sedp file via SFTP directly to the root of the PAS ?
I have also tried using Power Commissioning App however same issue, it timesout.
  • Thumbnail of EcoStruxure Panel Server Universal
View products (1)
  • troubleshooting
UdhayakumarAK
Commander UdhayakumarAK Commander
Commander
Posted: ‎2023-12-05 07:22 PM . Last Modified: ‎2023-12-05 07:25 PM
Hi Wasabi @wasabi
As you have already pointed out on slow network it is an obvious reason for the time out. Firmware update requires a stable, reliable & faster connectivity to the device.
As of now, SFTP in PAS is only for publication and not enabled for any file upload like FW upgrade. So its not possible to do Firmware upgrade via SFTP. (likely part of Cybersecurity reason).
Regards
Udhayakumar A K
ESXP System Support Expert
View products (1)
Guillaume_Evrard
Captain
Posted: ‎2023-12-04 09:20 PM
Sometimes using Edge Management Portal (EMP) it can success, but if you have a bad connectivity you might increase your data consumptions with multiple retries.
Kind Regards
UdhayakumarAK
Commander
Hi Wasabi @wasabi
Regards
Udhayakumar A K
View products (1)
