Reset of TH110 Sensors
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • Reset of TH110 Sensors
Romain_Polette
Kirk Romain_Polette Kirk
117
Guillaume_Evrard
58
Randi_Dolan
46
Panel Server Entry
Alexander_Akulov
Crewman Alexander_Akulov Crewman
Crewman
Posted: ‎2025-03-27 05:13 AM
1318
Currently we are changing ZBRN concentrators to PAS600. The main question is how to reset(unpair) TH110 sensors in order to pair them to newly installed PAS600
  • Thumbnail of Panel Server Entry
    Panel Server Entry
View products (1)
  • Commissioning
  • Legacy Gateways & Energy Servers
  • troubleshooting
Guillaume_Evrard
Captain
Posted: ‎2025-03-27 11:03 PM
4
1286
Hello @Alexander_Akulov
ZBRN can not unpair a TH110, it can only delete the TH110 from its config but the sensor remained paired forever.
As of today there is not handy procedure except the empirical one which is not doable on real set-up. It is recommended to replace all TH110 by new ones paired to the PAS.
PAS like PTL have the capability to unpair the sensor ( delete = unpair if sensors are communicating with the PAS)
Kind Regards
Replies 8
Romain_Polette
Kirk
Posted: ‎2025-03-27 08:45 AM
Hello @Alexander_Akulov ,
Please unpair the TH110 from the ZBRN gateway first. This will "release" the TH110 and enable them to be paired with a Panel Server. Refer to the ZBRN user manual.
If you do not follow this procedure, this will be very difficult to pair the TH110 with Panel Server.
Romain POLETTE
Solution Architect - France Operations
Guillaume_Evrard
Captain
4
1287
Kind Regards
Alexander_Akulov
Crewman
Posted: ‎2025-03-27 11:28 PM
1284
Hello @Guillaume_Evrard,
The equipment is already assembled. We have 292 sensors in total. It will be extremely hard to change 30% of sensors without disassembling. In case there is even a little chance that empirical way that may be applied to release sensors will work, we would like to try. Could you please share your experience with us  about any known possibilities to reset sensors?
Really appreciate you support.
Guillaume_Evrard
Captain
Posted: ‎2025-03-27 11:33 PM
Can you reach out to me please ?
Kind Regards
Luca_Rottoli
Luca_Rottoli Cadet
Cadet
Posted: ‎2025-10-20 05:54 AM
435
Hi @Guillaume_Evrard , are there any news about TH110 sensor unpairing? I accidentally deleted the configuration from ZBRN and now I need to re-pair all the TH110 sensors. Is there a way to un-pair the sensors and reset them to 'Ready to pair' mode? Thanks in advance
javier.mayo
Crewman javier.mayo Crewman
Crewman
Posted: ‎2025-10-21 12:04 AM
Hi, don't you have a backup of zbrn32?
javier.mayo
Crewman
Posted: ‎2025-10-21 12:11 AM
If you don't have a ZBRN backup, the only solution is to unpair the TH110 sensors by injecting 20 amps for 20 minutes to the TH110 sensors, and then wait 3 minutes before pairing again.
Guillaume_Evrard
Captain
Posted: ‎2025-10-21 10:32 PM
hello,
I reached out to Luca.
