Panel Server video – connect a Panel server to the Schneider Electric cloud Services
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • Panel Server video – connect a Panel server to the Schneider Electric cloud Services
Romain_Polette
Kirk Romain_Polette Kirk
117
Guillaume_Evrard
59
Randi_Dolan
46
EcoStruxure Panel Server Universal
EcoStruxure Panel Server Advanced
Thierry_Baudard
Commander Thierry_Baudard Commander
Commander
Posted: ‎2022-11-16 08:27 AM
12
5970
hereunder a video about connection of Panel Server to the Schneider Electric Cloud Services.
1st part is about the “nominal case”
2nd part is oriented on the diagnostic and troubleshooting.
Note that the max performance of Panel Server today with fw1.4 is
  • Max number of measurements: 2000
  • Max measurement flow: 500 measurements /minute
[video]
Thierry BAUDARD
EcoStruxure Power- Technical Support Expert for Softwares & Solutions
  • Thumbnail of EcoStruxure Panel Server Universal
  • Thumbnail of EcoStruxure Panel Server Advanced
View products (2)
  • Commissioning
  • troubleshooting
Eric_HAVAS
Lt. Commander Eric_HAVAS Lt. Commander
Lt. Commander
Posted: ‎2023-06-10 06:14 AM . Last Modified: ‎2023-06-11 08:22 AM
4894
Hi @CamiloEnergy ,
1/ Can you check the panel server firmware is the latest (currently 001.006.00), if not please upgrade
2/ Can you check with your IT that your panel server has the correct network settings to push data out:
Have you configured DNS parameters?
Is an http or https proxy required to push data out from your network?,
Can you check that the url given in "Enabling Schneider Electric Cloud Infrastructure" chapter of the user guide     are authorized
Replies 12
TomeLu
Commander | EcoXpert Master TomeLu Commander | EcoXpert Master
Posted: ‎2022-11-24 07:00 PM
5855
Hi @Thierry_Baudard
no video
Can you upload it again?
or video link
Fredrik_Aandal
Ensign Fredrik_Aandal Ensign
Ensign
Posted: ‎2022-11-28 04:18 AM
5810
@Thierry_Baudard
I have a PAS800 installed at our Innovation Hub in Oslo, Norway. Its not able to connect to cloud, "Connection In Progress" keeps spinning but never connects. It has internet access and firewall are open. I have another PAS that connected successfully and works as intended.
Can you please point me in the right direction on where to get support?
Guillaume_Evrard
Captain
Posted: ‎2022-11-28 05:22 AM
Is your Panel server synched to UTC ?
Have you configured the Proxy if in SE site ? https or http ?
Thierry_Baudard
Commander
Posted: ‎2022-11-29 02:00 AM . Last Modified: ‎2022-11-29 02:02 AM
Hello @TomeLu ,
The video is just viewable in the post and it is not possible to download it.
Thierry BAUDARD
Thierry_Baudard
Commander
Posted: ‎2022-11-29 02:07 AM
5766
@Fredrik_Aandal
What is the Connection diagnostic associated to the connection status "in progress" ?
example of diag in picture hereunder
Thierry BAUDARD
Fredrik_Aandal
Ensign
Posted: ‎2022-11-29 10:59 PM
5724
@Thierry_Baudard
Thanks for your reply.
"Device not registered" is the connection diagnostic.
Thierry_Baudard
Commander
Posted: ‎2022-11-30 09:57 AM
5699
@Fredrik_Aandal
In my opinion, it means that your Panel Server is not correctly instanciated in the SE cloud.
No way to fix the problem on your side (all your settings  looks correct)
Preliminary questions:
 - Is it a real commercial product Or a R&D developement sample previously delivered to SE countries ? (R&D dev product are not supported by SE cloud.)
- What is the fw version ?
Depending of your answer, the next step could  be to open a ticket for support and in this case, @Eric_HAVAS  will provide info for this.
Thierry BAUDARD
Fredrik_Aandal
Ensign
Posted: ‎2022-11-30 10:54 PM
1
5685
@Thierry_Baudard
Thanks a lot for prompt answers and excellent support.
- FW is 1.5
- I don't know if the PAS in question is a real commercial product, but I guess its a quite early one. Is it possible to identify by serial?
One more question as I have your attention:
Import of Modbus map from an "unknown" device is possible, but in what file format? Do I need access to some tool to generate an importable file? If yes, who may I ask to get access to it?
Thanks again,
Eric_HAVAS
Lt. Commander
Posted: ‎2022-12-01 08:19 AM
Hello @Fredrik_Aandal
I will process your technical issue outside this forum. I come back to you asap.
regards
Eric
CamiloEnergy
CamiloEnergy
Cadet
Posted: ‎2023-06-09 02:44 PM
4905
@Eric_HAVAS Hi Eric, my pas800 does not work with sftp publications and does not connect to the cloud, can you help me?
Eric_HAVAS
Lt. Commander
4895
Hi @CamiloEnergy ,
CamiloEnergy
CamiloEnergy
Cadet
Posted: ‎2023-06-12 03:07 PM
Hi @Eric_HAVAS
I already have the version, 1.6
I'm at home, what is the DNS?
I'm at home, which is the proxy?
I am in a residential network, I do not understand what I should put in proxy and dns. I need help
