I can't connect the two PM5560 measuring devices to the server panel via EPC. The connection is a Modbus line connection with an end-of-line resistor at one of the measuring devices. I have already configured both PM5560 measuring devices at 9600 baud with odd parity. I still can't see the two PM5560 measuring devices on the Ecostruxure Power Commission platform. Thank you for your help.
Hello @Sidym ,
can you detect both PM5560 on your Panel Server Web interface ?
If yes, did you enable Modbus TCP services on your Panel Server ?
Please check the Virtual IDs of your PM5560 attributed by the Panel Server to your devices. On EPC, please use Panel Server IP + Virtual IDs to detect the devices.
EPC supports PM5560 with FW 2.7.4 or higher, check your PM5560 version.
I understand that you have wired PM to PAS using RS485 modbus interface. Are you sure of the +/- wiring.
Have you configured the modbus port on PAS to match the modbus config of your PM ?
Are you sure you have modbus Id configured on PM ?
Are you adding the PM manually or are you trying to discover them in PAS ?
You have to configure this page in PAS web pages :
Kind Regards,
