PM5100 METER DIGITAL OUTPUT TO COMX510 TO VIEW kWh consumption
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • PM5100 METER DIGITAL OUTPUT TO COMX510 TO VIEW kWh consumption
Romain_Polette
Kirk Romain_Polette Kirk
106
Guillaume_Evrard
Commander Guillaume_Evrard Commander
49
Randi_Dolan
46
Thierry_Baudard
Commander Thierry_Baudard Commander
32
XtianPilarcA
Lieutenant JG XtianPilarcA
Lieutenant JG
Posted: ‎2020-10-23 01:28 AM
954
Dear All,
Good day. Since the absence of communication option of PM5100, Is it posible to use the digital output of the said meter's model to comx510 for kWh monitoring via COMX510 web server?
Thank you.
Randi_Dolan
Commander
Posted: ‎2020-10-23 06:06 AM
Hi Romain,
No, we are not planning on integrating the PM5100 as a Pulse Meter.  I can mention it to the Offer Manager and see if this is something we'd like to add in the future.
Best regards,
Randi
Romain_Polette
Kirk
Posted: ‎2020-10-23 02:19 AM
949
Hi @XtianPilarcA ,
You can connect the DO of the PM5100 directly on a Digital Input of the Com'X510. Please refer to the Com'X510 IS for wiring instructions.
PM5100 is not natively supported by the current 6.5.5 Com'X510 firmware. You need to create a device based on a Pulse Meter Custom Model. You will need to define what is the Pulse Weight and some other parameters.
@Randi_Dolan Do you know if the next Com'X 510 FW will integrate the PM5100 as a Pulse Meter in the library ?
Thanks.
Romain POLETTE
Solution Architect - France Operations
Randi_Dolan
Commander
Hi Romain,
Best regards,
Randi
