We have a photovoltaic system installed on our plant, which uses Huawei Smartlogger.
We have a PAS800 panel server used to log all kind of data in the plant and I would like to add the SmartLogger to the PAS800.
How can I add it as a custom device? Both device is connected to our network through TCP.
@BZsala ,
Can you click on this button ?
Hello @BZsala ,
If your Smart Logger have embedded Modbus Table, you can integrate your Huawei device into Panel Server.
Please refer to the guide to learn mode about Custom Model and EPC Web tool:
Another possibility: Replace the Smart Logger by the PAS800. If all your field devices can communicate through Modbus Serial (RS485) and Modbus TCP (Ethernet) you can integrate them into PAS800 interface.
As the manual states, I'm trying to use the EcoStruxure Power Commission web portal tool (EPC Web tool),
But if I want to create a new model it just says no model has been found and won't let me past.
@BZsala ,
