PAS800 Server Panel Historical Data Access
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • PAS800 Server Panel Historical Data Access
Romain_Polette
Kirk Romain_Polette Kirk
117
Guillaume_Evrard
59
Randi_Dolan
46
EcoStruxure Panel Server Advanced
Samart_Ploypradab
Ensign Samart_Ploypradab Ensign
Ensign
Posted: ‎2023-09-25 03:10 PM
5713
Does the PS800 Server Panel allow PME or 3rd party software to access its historical data? Via Protocol?
It similar like PME able to read datalog in Power meter?
  • Thumbnail of EcoStruxure Panel Server Advanced
View products (1)
  • Legacy Gateways & Energy Servers
Thierry_Baudard
Commander Thierry_Baudard Commander
Commander
Posted: ‎2023-10-12 02:46 AM
Hi all,
Two additional info:
  - the  format of the csv export from  the Panel Server will not be modified because used by several clients (PME + SE advisors) who does not expect the same format  so not possible to align for all  at Panel Server Level.
 - Solution currently in dev/validation between PME and Panel Server teams for a better integration (timeline not communicated for the moment)
Thierry BAUDARD
EcoStruxure Power- Technical Support Expert for Softwares & Solutions
Szymon_Hochół
Captain Szymon_Hochół Captain
Captain
Posted: ‎2023-10-18 07:17 AM
I can confirm what @Thierry_Baudard wrote below. The format of CSV file from PAS will stay as it is, however the ETL will be updated to be compatible with it. The solution should be already available via Tech Support on case-by-case basis, so if your project requires ETL integration of PAS files I would suggest to reach out to Tech Support. This is expected to be released at some point, but I do not have firm date to share.
BR
Replies 20
Romain_Polette
Kirk
Posted: ‎2023-09-25 11:40 PM
Hello @Samart_Ploypradab ,
PME cannot read internal log of the Panel Server.
PME can read onbard logging only if your Power Meter:
  • communicates through ION protocol (ION7650, PM8000, ION9000, ...)
  • has a driver able to read onboard log (PM5000, PM3000)
I do not know if the Panel Server is now compatible with the ETL tool of PME (just like Com'X510).
The goal is to make Panel Server publish .csv file and use ETL to import the .csv data to PME database.
Romain POLETTE
Solution Architect - France Operations
Samart_Ploypradab
Ensign
Posted: ‎2023-09-26 04:35 AM
Hello @Romain_Polette
Thank you for your reply.
Romain_Polette
Kirk
Posted: ‎2023-09-27 12:39 AM
You will find more info about CSV file format here.
In case of manual export:
https://www.productinfo.schneider-electric.com/ecostruxurepanelserverguide/doca0172-ecostruxure-pane...
In case of automatic publication:
Romain POLETTE
Romain_Polette
Kirk
Posted: ‎2023-09-27 02:12 AM . Last Modified: ‎2023-09-27 02:14 AM
I can see that the CVS format of a Panel Server publication file is close to a Com'X510 CSV (picture below).
The difference is with the Topic ID:
  • Com'X 510 is using a specific number (1018, 24052, ...) => These numbers are aligned with the Topic ID inside PME database
  • Panel Server is using a chain of characters ("modbus:1_mb_VAB","modbus:1_mb_VAN"= => These characters are not compatible with the PME Topic ID system.
So for the moment, I do not see any simple solution to transfer PAS800 data into PME database.
Romain POLETTE
geir_eas_no_bfo
Lt. Commander geir_eas_no_bfo
Lt. Commander
Posted: ‎2023-10-06 07:14 AM
after my understanding only option for PAS is to push data to SFTP folder on a computer, and not as a cheduled e-mail publications?
Have several customers that need to forward historical data through email.
BR
GIA
matt_azzo_com_a
Lieutenant | EcoXpert Master matt_azzo_com_a Lieutenant | EcoXpert Master
Posted: ‎2023-10-08 07:09 PM
Hi @Romain_Polette
It's unfortunate to see that ETL import into PME is not supported for this advanced datalogger, which has been marketed as a direct replacement for the Com'X range (which is discontinued and no longer available).
Can you please give us a timeline for an update to either the PAS firmware or ETL to support this essential data transfer functionality?
Matt
Romain_Polette
Kirk
Posted: ‎2023-10-08 11:47 PM
5591
Hello @matt_azzo_com_a ,
Maybe @Szymon can update us:
  1. Do you know if the Panel Server CSV format will be adapted to be compatible with ETL Tool ?
  2. Any release of new ETL planned ?
Romain POLETTE
Thierry_Baudard
Commander
Hi all,
Thierry BAUDARD
Szymon_Hochół
Captain
BR
Szymon_Hochół
Captain
Posted: ‎2023-10-25 12:04 AM
2
5486
The fix to load CSV files coming from PAS using ETL is now released and available here: ETL EGX extract task fails for PAS600 and PAS800 FW 1.6.0 csv files | Schneider Electric India (se.c...
BR
matt_azzo_com_a
Posted: ‎2023-10-25 12:23 AM
5476
Thanks @Szymon_Hochół , I have applied this fix, however I can see that even after removing the " symbols, this still leaves another issue.
For the ComX or EGX import tasks, the SourceID for the quantity mappings was the TopicID, and these were the same across all sources.
In the PAS files, the StartID value for quantity mappings appears to be unique for each source. This requires the user to find, define the end-names, and map the quantity mappings for each source (rather than having just one measurement which is common to all sources).
Is there any possibility of this being addressed?
geir_eas_no_bfo
Lt. Commander
Posted: ‎2023-11-01 07:28 AM
A customer uses ComX510 as a datalogger and publish, csv files trough e-mails to a third-party energy system. The ComX is unstable in theire facillitys, and need to be replaced.
Don`t understand why IFE server has this CSV- email opportunity, but not PAS800?
BR
GIA
MarianTodorov
Ensign MarianTodorov Ensign
Ensign
Posted: ‎2023-11-10 01:34 AM
5326
Hello @Szymon_Hochół ! Do you know if this fix is applicable also when PAS FW is 1.7?
Best regards
karina.romero
Ensign karina.romero
Ensign
Posted: ‎2023-11-13 04:46 PM
Hi @matt_azzo_com_a , Did you find a solution to use ETL tool with a Panel Server csv format considering that TopicID is not a specific number?
Szymon_Hochół
Captain
Posted: ‎2023-11-15 01:03 AM . Last Modified: ‎2023-11-15 01:04 AM
Hi @MarianTodorov,
To my knowledge the format was changed in v1.6 and stayed the same since then. So it should apply to v1.7.
Stuart_Cheng
Lt. Commander Stuart_Cheng Lt. Commander
Lt. Commander
Posted: ‎2023-12-11 01:28 AM . Last Modified: ‎2023-12-11 05:03 PM
5155
Hi All,
I read the discussion loop above and knew that PME cannot read the onboard logging of the Panel Server.
Would like to check if this function is on the future roadmap ? Or ETL tool is the only way to integrate data into the PME database?
Szymon_Hochół
Captain
Posted: ‎2023-12-11 09:06 PM
2
5139
Hi @Stuart_Cheng ,
ETL is the only way to get historical data logged by PAS to PME system.
BR
karina.romero
Ensign
Posted: ‎2023-12-12 01:53 PM
Hi @Szymon_Hochół Were you able to get historical data logged by PAS to PME? I noticed that even after removing the " symbols, this still does not work. ETL cannot read the csv file as TopicID, Device LocaI ID and Device Type ID are not numerical data.
karina.romero
Ensign
Posted: ‎2023-12-13 03:08 PM
5109
Could you do it? The ETL tool is not accepting my csv file as TopicID, Device LocaI ID and Device Type ID are not numerical data.
Szymon_Hochół
Captain
Posted: ‎2023-12-13 11:51 PM
Hi @karina.romero ,
in case you experience issues with ETL process, I strongly recommend to raise a case with Tech Support.
BR
