| User | Count |
| 116 | |
| 58 | |
| 46 | |
| 32 |
The default logging period for the PAS800 is 10 minutes by default. Unfortunately this differs from the PME default for the iEM3000 meters, which is 15 minutes. This will lead to mismatching database entries when ETL is use to backfill data after a comms loss.
We see no problem with to changing the PAS800 interval from 10 minutes to 15, except there is no 'one drop-down setting to changes all measurements on the meter'. This means I have to manually change each of the 19 individual sampling intervals to 15 minutes. This is going to use a fair bit of time when considering we have 40 of these meters per site giving a total of 760 individual changes from 10 minutes to 15 minutes per site.
Can an additional feature be added per with a drop down box to change all the measurements to the same interval i.e. 15minutes? It could appear beside the sampling tick box (see attached picture).
Thank you,
Sam
Do you know if the global data sampling setting issue has been fixed with the latest firmware?
Best regards
It is not yet fixed with the current fw version 1.5.0 but it will be in the next one 1.5.1
The webpage will offer you the possibility to select all the measurements of a product in one click and to modify the sampling period only one time for all the selected measurements.
Hello @Thierry_Baudard ,
v001.005.001 was planed for last month. Does the dev team plan to release this version on Fabruary ?
Thanks.
