No green power light on Com'X 210
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • No green power light on Com'X 210
Romain_Polette
Kirk Romain_Polette Kirk
106
Guillaume_Evrard
Commander Guillaume_Evrard Commander
49
Randi_Dolan
46
Thierry_Baudard
Commander Thierry_Baudard Commander
32
swil
Commander swil
Commander
Posted: ‎2019-06-25 02:25 PM
935
I have a new Com'X 210 that I did not think was communicating with the network over ethernet port 2.
I had configured it the same as others that were working.  Only the ethernet light was working (green)
On reboot, the orange light for power would display and then disappear.
Thought it was broken. Repeated the factory reset and found that was able to reconnect to it and reconfigure (after orange powerlight and then no power light).  It works now and is sending data to PME.
The green power light still doesn't go on. Should I ask for a replacement or will everything likely be OK?
Randi_Dolan
Commander
Posted: ‎2019-06-26 05:11 AM
I'm sorry to hear that you've had some issues with your Com'X210.  If your Com'X is operating correctly, I think that it would continue to operate correctly.  However, there is a hardware issue (maybe just a bad LED or a bad solder joint).  If it is important to see that the Power LED is illuminated, then I would return it.
Randi
Randi_Dolan
Commander
Randi
Khoa_NTM
Lieutenant | EcoXpert Master Khoa_NTM Lieutenant | EcoXpert Master
Posted: ‎2019-08-28 11:50 PM
I meet the same.
Now I config OK
