Link150 factory reset
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • Link150 factory reset
Romain_Polette
Kirk Romain_Polette Kirk
117
Guillaume_Evrard
59
Randi_Dolan
46
AndersDahlskog
Lieutenant AndersDahlskog Lieutenant
Lieutenant
Posted: ‎2020-09-03 01:53 AM
5334
Hi
Have tried to do this according to user guide and FAQ FA295374. It will not reset and Module Status LED is not flashing when pressing IP reset pin (steady green).
Existing IP adress is good and it is possible to log in as Guest. The administrator password is lost so want to return to default user name and password.
Any other ways do a factory reset ?
BR/Anders PAE EcoStruxure Power, Sweden
Replies 9
Posted: ‎2020-09-17 03:33 AM
5324
Hi @AndersDahlskog,
I have noticed that your topic is still unanswered.
I was wondering if you found a solution on your side. If you did, I kindly invite you to share it with the community.
But if you still in the same situation please do not hesitate to inform us here.
AndersDahlskog
Lieutenant
Posted: ‎2020-09-17 04:05 AM
5322
Hi
I haven´t found a solution. If a factory Reset is not possible to do to retrive factory login credentials we have to recommend customer to buy a new product.
BR/Anders
Posted: ‎2020-09-18 02:21 AM . Last Modified: ‎2025-08-12 05:24 AM
Hi the community members can you help this member, please?
@Romain_Polette do you think you can advise on this topic?
acmoore
Crewman acmoore
Crewman
Posted: ‎2023-02-03 07:45 AM
I see this topic is a couple years old, I actually ran across this because I was experiencing the same issue today and found this looking for help.  As it turns out, I use the Administrator Username and the old password Gateway.  This allowed me to link to the controller and complete setup.  Hopefully this information will help someone else in the future.
wasabi
Lieutenant JG wasabi Lieutenant JG
Lieutenant JG
Posted: ‎2023-02-20 03:30 PM . Last Modified: ‎2023-02-20 05:35 PM
I did face this issue however it was resolved by holding down the pin hole reset button for 10-15seconds then release. the Administrator account will be reset after reboot default password will be the MAC ID EG
0080F470B870 - all in CAPS
https://www.productinfo.schneider-electric.com/link150ug/link150-ug/English/BM_Ethernet%20Gateway%20...
RInouye
RInouye
Cadet
Posted: ‎2024-09-04 11:08 AM
I could not get my EGX150 password to reset after doing a factory reset, so i came here to see if i was missing something. Turns out, the default password listed in the documentation was incorrect. User Acmoore is the only one with the right answer, the default password on my unit is Gateway!
Schnieder, please update your documentation!
If you're trying to reset the password on your EGX150 and the MAC address password is not working, try Gateway. There must be some in between models that did not get documented properly
Romain_Polette
Kirk
Posted: ‎2024-09-10 02:53 AM
Hello @RInouye ,
"Gateway" default password was dedicated to old Link150 FW.
Newer version with CyberSec improvements uses MAC Address as default PW. I recommend to download v5.3.3 on se.com and upgrade your Link150.
Romain POLETTE
Solution Architect - France Operations
chsj
chsj
Cadet
Posted: ‎2025-02-17 08:01 AM
Hello @Romain_Polette
I have a link 150 on Fw5.3.3 and when I press the pin hole reset button for 10-15seconds then release the device does not appear to reset the Administrator password to the MAC (eg 0080F4AADDA0)
The link150 device does look like it is doing the factory reset (modbus status blinking red and then steady green  after 10-15 sec) but I'm still not able to log in.
I know the guest password and I can see the that account is not being reset either (default guest/guest)
I'm I missing a step in the factory reset process?
kind regards
Christian
Romain_Polette
Kirk
Posted: ‎2025-02-18 12:59 AM
Hi @chsj ,
I think your issue must be checked by tech support because your are doing Factory Reset right. I do not know any other procedure...
If the Administrator pwd is not reset to default (MAC address for most recent FW), there is an issue with your device.
Connect your Link150 to the Link150 FW Upgrade Tool and check if your FW is confirmed as 5.3.3. Is the FW from factory ? Or did you upgrade your Link150 with the tool ? Do you remember the previous FW version ?
Romain POLETTE
