asked how many EnOcean devices you could put on an MPM. The answer is 49. Prior to 2.13, you could only have 20 devices on the same profile, however, this limitation is now gone.
Having said that, if you were to use Lua scripts, you could "in theory" have an infinity of devices, however this is not recommended to have more than the defined limit to maintain the performance of the box. As usual, you will have to take into account all the other things you are running and connecting to the box to ensure that it runs smoothly. I would always recommend for you to test a given setup before selling it and deploying it to the field.
Can same be integrated on SBO. Is there a documentation from Schneider explain same?
