How FTP file can be pushed in the system while logging data from EGX through team viewer?
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • How FTP file can be pushed in the system while logging data from EGX through team viewer?
Romain_Polette
Kirk Romain_Polette Kirk
117
Guillaume_Evrard
59
Randi_Dolan
46
sesa125036_brid
Lieutenant sesa125036_brid Lieutenant
Lieutenant
Posted: ‎2014-07-06 11:12 PM
1254
While we are supporting clients online through remote access like team viewer we are unable to activate login data as remotely FTP pushing is not happening. Please let us know how we can do this. Thanks
Replies 5
LaurentCoene
Captain LaurentCoene Captain
Captain
Posted: ‎2014-07-07 01:07 AM
1193
Hello!
Sounds weird. The ports used by Team Viewer and the FTP push are different. You shouldn't have this kind of problems. One thing to know is that you need to have something to push in order for the push to happen. If your device log export schedule is set to interval or interval or hourly, it will only try to push what hasn't been sent yet. However if you set it to daily, weekly or monthly, then it will push the entire stack. Change the interval, save and try to push.
Hopefully that will do the trick. (remember to roll back to whatever it was once you've finished to troubleshoot the issue).
Hope this helps. Otherwise, give us some screenshots maybe so that we can try to help.
sesa125036_brid
Lieutenant
Posted: ‎2014-07-07 01:13 AM
I would like Debmalya to respond to this.
arjanbijker
arjanbijker Schneider Alumni (Retired)
Posted: ‎2014-07-09 12:33 AM
1193
Hi Gautam,
have you checked if you can access the FTP server from the customer's network?
Maybe a firewall is blocking outgoing FTP.
Also, check the logs on the COMX200, to troubleshoot it.
sesa125036_brid
Lieutenant
Posted: ‎2014-07-09 01:05 AM
1193
It was case related to the EGX300. anyways, the person is looking at the case now, with inputs from you and Laurent.
arjanbijker
Posted: ‎2014-07-09 01:08 AM
If the EGX300 is not pushing data, you can always consider "pulling" it
from it, i.e. connecting to the EGX300 via FTP and download the logs.
