Hi, currently trying to email from a ComX510 to one of our email accounts.
Needs to work across Wifi, has worked initially but all subsequent attempts after have failed
Direct Ethernet connection works every time
Using a Local SMTP server.
Any ideas
Posted: 2016-12-06 06:18 AM
Hi James,
Are you still encountering this issue? If so, please help me with the following information:
- What firmware version are you using for the ComX510?
- Does the ComX510 show WiFi signal strength when it is failing?
Best Regards,
Colton Peltier
