EcoStruxure Power Commission can be used for PAS600?
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • EcoStruxure Power Commission can be used for PAS600?
Romain_Polette
Kirk Romain_Polette Kirk
117
Guillaume_Evrard
58
Randi_Dolan
46
RogelioHdezD
Ensign RogelioHdezD Ensign
Ensign
Posted: ‎2023-01-25 08:53 AM
1673
Hi colleagues!
What can be done with EcoStruxure Power Commission when configuring and commission a PAS600 that gathers data from Power Meters (PM5560)?
Rogelio Hernández Dguez
SIT
  • Commissioning
Replies 4
Thierry_Baudard
Commander Thierry_Baudard Commander
Commander
Posted: ‎2023-01-25 09:27 AM
Configuration of PAS600 does not change in EPC according to the type of downstream Modbus SL connected products (PM5560 or other type)
you will be able to configure paremeters such as Ethernet parameter/modbus serial line parameters (just some examples but not the exhaustive list!)
Please refer to EPC on line help for more information about this.
BR
Thierry BAUDARD
EcoStruxure Power- Technical Support Expert for Softwares & Solutions
Romain_Polette
Kirk
Posted: ‎2023-01-25 10:41 AM
1658
Hello @RogelioHdezD ,
Can you precise your need ?
As mentioned by Thierry, if you want to commission the Panel Server + PM5560, your experience will change depending on the tool.
With PAS web pages, you can set up data sampling for your PM5560. With EPC: you can't. Same remark for the PM5560 alarms pushed by the Panel Server.
Web pages allow you to change the Virtual ID of you PM5560. EPC cannot change the Virtual ID attributed by the Panel Server.
To full commission the PM5560, you will need ION Setup. PM5560 web pages can also be used but ION Setup have more advanced settings for PM.
Romain POLETTE
Solution Architect - France Operations
RogelioHdezD
Ensign
Posted: ‎2023-01-26 04:53 AM
1653
Hi!
The specific need is to configure the PAS600 (Ethernet interface parameters, serial interface parameters, and slave devices). All of that can be done either with ECP or using the web page?  I am assuming that power meters would be configured with ION Setup.  Thanks!
Romain_Polette
Kirk
Posted: ‎2023-01-26 05:11 AM
Answer is yes.
You must switch EPC in "COMMUNICATION VIEW" -> select your Panel Server (click the gear wheel).
You will access to :
  • the ETH setting of your PAS600
  • Serial bus settings
Slave devices are normally auto detected by the PAS600 during Modbus Device discovery. But if you change the Slave ID on your serial device, you can update the Slave ID with EPC (not in the Communication View but by selecting directly the slave device on the left pane of EPC).
Let me know if it helps.
regards,
Romain POLETTE
