EGX300 stopped working after updating firmware 4.40?
Gateways and Energy Servers
Send InviteCancel
2016-10-2211:54 PM
I wanted to upgrade one set of EGX300 Via Command Prompt. I have followed bellow instruction as per our website. Managed to connect FTP But after sending the .bin file the EGX300 shut down all the ports. No Default as well previous IP is working. But all LED is blinking normally that means data transfer between serial device and Ethernet is taking place. Is there any solution on that?
"" To upgrade EGX100, EGX300 or PM8ECC via the command prompt: 1. Download the firmware and place it on your desktop 2. Open the command prompt (Start > run > type cmd and hit enter) - Note: depending on windows account one may need to right click on the icon and select run as administrator instead of hitting enter 3. Type FTP and hit enter 4. Type open followed by the IP Address of the gateway 5. Type user name and Hit Enter (The User name by default is Administrator) - Note: User name and password are case sensitive 6. Type password and hit enter. It will not show the password being typed (The password by default is Gateway) 7. Type send and press space, then drag the firmware from desktop to cmd window and hit enter. 8. After completion of the download, type quit at the ftp> prompt and press enter.
If firmware update completes successfully, you will see "Transfer Complete" and the number of bytes sent and time.
