EGX 300 SMTP Login Failure
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • EGX 300 SMTP Login Failure
Romain_Polette
Kirk Romain_Polette Kirk
116
Guillaume_Evrard
58
Randi_Dolan
46
Miguel_Angelo
Lieutenant Miguel_Angelo Lieutenant
Lieutenant
Posted: ‎2016-10-10 06:14 AM
3
981
Hi
Im getting this error from EGX300 when is authenticating (Authenticating as veoliapt.delphi@netsystems.pt���������� )
Data send from EGX300
[2016.09.09] 17:36:35 [78.130.61.229][9009535] rsp: 220 webhosting.netsystems.pt - Hello 78.130.61.229 - Local Time is Fri, 09 Sep 2016 17:36:35 +01:00 - SMTP srv ready
[2016.09.09] 17:36:35 [78.130.61.229][9009535] connected at 9/9/2016 5:36:35 PM
[2016.09.09] 17:36:35 [78.130.61.229][9009535] cmd: EHLO egx
[2016.09.09] 17:36:35 [78.130.61.229][9009535] rsp: 250-webhosting.netsystems.pt Hello [78.130.61.229]250-SIZE 20971520250-AUTH LOGIN CRAM-MD5250-8BITMIME250 OK
[2016.09.09] 17:36:35 [78.130.61.229][9009535] cmd: AUTH LOGIN
[2016.09.09] 17:36:35 [78.130.61.229][9009535] rsp: 334 VXNlcm5hbWU6
[2016.09.09] 17:36:36 [78.130.61.229][9009535] Authenticating as veoliapt.delphi@netsystems.pt����������
[2016.09.09] 17:36:36 [78.130.61.229][9009535] rsp: 334 UGFzc3dvcmQ6
[2016.09.09] 17:36:36 [78.130.61.229][9009535] rsp: 535 Authentication failed
[2016.09.09] 17:36:36 [78.130.61.229][9009535] disconnected at 9/9/2016 5:36:36 PM
Best Regards
Miguel Gonçalves
Miguel Gonçalves
sesa111809_brid
sesa111809_brid Schneider Alumni (Retired)
Posted: ‎2016-10-10 07:33 AM
It appears authentication method "CRAM-MD5" is being used.  Perhaps try a different authentication method?
Miguel_Angelo
Lieutenant
Posted: ‎2016-10-14 02:31 AM
Tanks Barry
Miguel Gonçalves
Adrian_Dicea
Janeway Adrian_Dicea Janeway
Janeway
Posted: ‎2017-01-27 06:35 AM
The EGX300 supports: Plain, Login, CRAM-MD5 and Digest-MD5 access authentication, but using any of these options should be dictated by the server's answer, after EGX300 sends EHLO egx command to the SMTP server.
Looking at the info that you've sent, I am not sure why this line is:
After AUTH LOGIN command from EGX the response is correct from the smtp server, then EGX300 must continue with USER: "!@#$%" command where "!@#$%" must be an encrypted string, not the clear email address text as above.
Also, just in case you will pass this authentication step, you may double check the user name, it seems to be padded with extra characters at the end ����������
Anyway, your email export is failing before user and password validation step.
Is that provider's tech support able to support you?Which EGX firmware and DiskUpdate versions do you have?
