Does the PAS 600/800 Panel Server record the Panel Server ON and OFF times during power failures? If yes, how can we view the power failure time values?
Hello @Dilhan
If the PaS is connected to a scada, during power off/power, the scada is not able to retrieve any data so you should be able to get the duration of power off/on at scada level.
If the PaS is connected to a Schneider cloud application, as you will have an alarm notification of communcation loss after power off, you will have the duration of power off/on at your cloud application level.
Another solution is to have a look in the uptime available in PaS Web page: Maintenance /System Montoring, you can have easily when the PaS has been powered on or rebooted:
Duration of power off /power on is more complex, at only PaS Level, as will require PaS logs analyse which is not so easy as mainly for R&D team.
Regards
Eric
Hello @Dilhan
Regards
Eric
