Com'X 200 Analog Inputs
Gateways and Energy Servers
Send InviteCancel
2013-07-0901:01 AM
As you know, the Com'X200 has 2 analog inputs that allows you to plug in any 4-20mA or 0-10V sensor.
But it doesn't stop there! It also provides 24VDC so that you don't need to add another power supply to power your sensors.
In the following photo, you have a Veris TOAM10 External temperature sensor (4-20mA - the orange cables), and a Schneider Electric Lux sensor SLR320 (4-20mA - green and blue cables).
One limitation you need to be aware of: each input provides only 50mA, so you need to be careful to the types of devices you are plugin in.
For example, the Schneider Electric SCR serie (Temperature, Humidity and CO2 sensor) can draw up to 170mA, so you will still need an external power supply for these!
