COM'X200 Data upload to REM scaling problem
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • COM'X200 Data upload to REM scaling problem
Romain_Polette
Kirk Romain_Polette Kirk
117
Guillaume_Evrard
59
Randi_Dolan
46
arjanbijker
arjanbijker Schneider Alumni (Retired)
Posted: ‎2014-07-02 09:48 PM
5997
Hi All,
We have installed our first COMX200 and is publishing it to REM. We have upgraded it to the latest firmware.
For some unknown reason all values are divided by 1000! (See bold values in the output file!)
please can you have a look why this is happening??? This is extremely frustrating!
I have also attached the commissioning procedure we have followed.  We use 30 min standard in SA.
OUTPUT CUT....
,20140703040000,"00030216333762_Resource-0\Aerostructures Cooling Towers|1601\Active Energy Into the Load",OK,E,kWh,0.001,00000030,2,201407030300,,3.1270000000004075,,,3.1279999999997017
,20140703040000,"00030216333762_Resource-0\Aerostructures Cooling Towers|1605\Reactive Energy Into the Load",OK,E,kVArh,0.001,00000030,2,201407030300,,8.423999999999978,,,8.434999999999945
Posted: ‎2014-08-24 11:47 PM
5713
Hi, Arjan
This issue is solved  with the new firmware V1.1.20, can be found at the following link:https://schneider-electric.box.com/s/vp659224ty3ss6ql4fj4
Note that :This forum is not monitored by our EMS support team, so we recommend you to send your requests to: global-ems-solutions-support@schneider-electric.com
which guarantees the answer in time according to SE requirements.
Best Regards
Lazaro
Replies 31
luca_gasparini
luca_gasparini Schneider Alumni (Retired)
Posted: ‎2014-07-03 09:14 AM
5713
Unfortunately, we have the same problem!!! ..and also for us is the first COM'X200 installed.
We have already opened a support request to 'global-ems-solutions-support' (No answers yet).
Here are the details:
Case Reference #: 11596575
Subject: Re: Com'X200 - Energy Operation Online
Date Created: 26.6.2014
Case ID: ref:_00DA0abSm._500A0LN41k:ref
JamesJeanette
Commander JamesJeanette Commander
Commander
Posted: ‎2014-07-03 09:22 AM
Hi Arjan/Luca,
Let me see what I can do to help.  Just curious...how long ago did you report this to Global Support?
- Can you check on this one? [Case Reference #: 11596575]
James
nigel_greenwave
Admiral | EcoXpert Master nigel_greenwave Admiral | EcoXpert Master
Posted: ‎2014-07-03 11:31 PM
2
5713
I'm sitting with a confused client! It seems clear to me that the EBX200 was not tested in this area? @Schneider Team is there any news regarding a fix?
sesa11375
sesa11375 Schneider Alumni (Retired)
Posted: ‎2014-07-04 02:23 AM
1
5713
Hello, I'm the quality leader for COM'X offer, we are investigating this issue, we will go back to you soon.
Catherine
arjanbijker
Posted: ‎2014-07-04 02:26 AM
thank you very much Catherine,
LaurentCoene
Captain LaurentCoene Captain
Captain
Posted: ‎2014-07-04 02:59 AM
5713
Hi Arjan,
I've only been pushing to EO, so haven't seen this. But can easily test. Was it with any type of meter? Which one are you using?
A work around would be to push to "3rd party" which uses the EGX300 file format. Since REM supports the EGX file format, it should do the trick (even though I personally prefer the CMEP file format which is more compact).
3rd party is the "CSV export" option.
4095
At least until we have more time to investigate, you can sort out your customer.
sesa11375
Posted: ‎2014-07-08 04:28 AM
12
5713
We have fixed the problem. This will be corrected in V1.1.20 of COM'X 200 firmware which will be available at the end of the month on SEC.
dborle
dborle Schneider Alumni (Retired)
Posted: ‎2014-07-08 05:40 AM
5713
Hi Catherine,
What about the strange timestamping of the Com'X that we have found on a site (was also reported on the SEC but I never got back an answer for this issue), will this also be corrected with the new version? I also made some tests here in the office with the same result. It seems that data have been sent randomly in the device (for example you can have 4 devices connected to the Com'X. Two have on an hourly base 4 entries, beginning with XX:00 and the rest of the devices with XX:15 or one device has suddenly only 3 entries and then on the next run 5).
Daniel
sesa11375
Posted: ‎2014-07-08 06:52 AM
5713
Hi Daniel,
I can see in SEC that Jef Maubert has started working on this issue, I will
check with him but he is vacation until the 21th of July.
you can also report your issue to the Customer Care Center at
Catherine
dborle
Posted: ‎2014-07-08 07:09 AM
5713
OK, thanks. I will see.
arjanbijker
Posted: ‎2014-07-15 05:16 AM
Hi Laurent,
We are trying the CSV export option now, but I see the COMX'200 is exporting it as a .ZIP file, and it seems that EVO/REM doesn't support ZIP files.
What now.......?
arjanbijker
Posted: ‎2014-07-23 02:49 PM
5713
Hi Laurent,
this "trick" is not working, since the EBX200 is exporting CSV not exactly the same as the EGX300 used to do.
Looks like the "return" characters have been stripped from the CSV file, notice in the screenshot below when you open them up in notepad.
Also, the rem / evo server rejects them.  I have set the correct date/time format to match egx300 format.
4211
nigel_greenwave
Posted: ‎2014-08-02 09:16 AM
Hi Arjan, as I'm sure you are aware I had to remove the 4 x COMX's from site as they are not suited to work on the REM platform. The client was putting pressure on us to complete the installation so we replaced them with the older non Schneider modems that work!
arjanbijker
Posted: ‎2014-08-04 05:40 AM
8
5713
Guys,
I was promised firmware end of july.  Any news?
JamesJeanette
Commander
Posted: ‎2014-08-04 08:52 AM
5713
Hello Arjan.  I have not yet received the firmware update to share.  Let me find the status.
arjanbijker
Posted: ‎2014-08-04 10:38 AM
5713
Hi james, i have received it now from global.
Sent from my iPad
sesa205726_brid
Lieutenant JG sesa205726_brid Lieutenant JG
Lieutenant JG
Posted: ‎2014-08-05 12:39 AM
Hi ArjanI
I sent the nwe firmware 1.1.20 to two customer and the problem of the measuring devided for 1000 was solved. Now in REM we read the measuring rightly,
JamesJeanette
Commander
Posted: ‎2014-08-05 11:11 AM
5713
Thanks for sharing.  I have received it as well and it will be posted today for everyone.
JamesJeanette
Commander
Posted: ‎2014-08-06 05:57 AM
5713
Com'X 200 Version 1.1.20 is now available on the Shopping Kiosk, or here on the SEC: https://powersolutionscommunity.schneider-electric.com/docs/DOC-2746
LaurentCoene
Captain
Posted: ‎2014-08-19 06:51 PM
5708
Hi James, does this release also fix the CSV file format (EGX file format) issue that was discovered in this thread?
arjanbijker
Posted: ‎2014-08-22 03:59 AM
5708
Hi Guys,
I am really concerned about the stability of the COMX200, in terms of network connectivity.
We have a device on a GPRS network which we need to manually reboot every week. (On the latest firmware).
This is a serious problem.
Can this be investigated ASAP?
JamesJeanette
Commander
Posted: ‎2014-08-22 08:05 AM
5708
Hi Arjan.  I apologize that you are experiencing these issues.  I will escalate to the engineering/quality team today.
Have you created any support ticket for this issue with global technical support?
James
5714
Hi, Arjan
Best Regards
Lazaro
arjanbijker
Posted: ‎2014-08-25 12:12 AM
5707
Hi lazaro,
We are using firmware 1.1.20
The issue still persists.
Sent from my iPad
arjanbijker
Posted: ‎2014-08-25 01:35 AM
HI James,
yes:
Schneider Electric Case # 12955857: COMX200 Negative data issue on pulse
inputs
nigel_greenwave
Posted: ‎2014-08-25 11:19 PM
3
5713
I'm now going to remove my 4th ComX from site!! This has been very embarrassing and costly for my company (not to mention Schneider). I cant believe that the ComX hasn't been field tested before released.
As I have mentioned in other posts the ComX has great potential but its not there yet.
dborle
Posted: ‎2014-08-25 11:22 PM
1
5713
Hi Nigel,
I fully agree with you as I have a little bit the same feelings about this product!
JamesJeanette
Commander
Posted: ‎2014-08-26 06:52 AM
Hi guys...I completely understand your concerns.  The Com'X 200 Engineering and Quality teams are aware of these issues and are working diligently to solve the problems you are facing.
James
sesa11375
Posted: ‎2014-08-26 07:11 AM
Hi Nigel, if the issue that makes you remove the COM'X is the division by 1000 in REM , it is solved with V1.1.20
best regards
Catherine
sesa11375
Posted: ‎2014-08-26 07:19 AM
1
5713
Hello all,
I feel that the thread has drifted from the initial topic which was the REM scaling problem. From my point of view this issue is solved with V1.1.20. Do you agree ?
I propose to close this topic and I will make a dashboard with the issues that I will find here or that you send me by mail.
I will share this dashboard in a BOX, and you will be able to complete/precise the issues. I will update the status of the issues in this dashboard.
What do you think ?
JamesJeanette
Commander
Posted: ‎2014-08-26 07:22 AM
I think this is best.  Thanks Catherine.
