I have a project to integrate readings from a condensate meter (steam) into PME. Either the COM'X 210/510 are being considered to read the scaled pulse output from the device depending on whether on-board data logging is required.
Considering that the sensor/meter has an NPN scaled pulse output, it is important that the COM'X digital input card be of the same type.
What type are the COM'X 210/510 digital inputs? (E.g. NPN or PNP). Depending on the type of the COM'X digital inputs we may or may not require a PNP to NPN converter.
Hady
Hi Randi,
Thank you for your response. I will wire this setup on a test-bench and let you know.
Hady
