Adding PowerTag A9MEM1540 to PAS600 Gateway
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • Adding PowerTag A9MEM1540 to PAS600 Gateway
Romain_Polette
Kirk Romain_Polette Kirk
108
Guillaume_Evrard
52
Randi_Dolan
46
Thierry_Baudard
Commander Thierry_Baudard Commander
32
ArcherWang
Lieutenant | EcoXpert Master ArcherWang Lieutenant | EcoXpert Master
Posted: ‎2024-01-17 01:59 PM
2490
Hi Huys,
I hope you're doing well.
My customer has opted to replace the old PowerTag Link Concentrator with a PAS600. I'm currently tasked with searching for and adding the Wireless PowerTags to the new PAS600 gateway, as shown in the photo below. However, it appears that nothing can be selected.
I'm working on this remotely through an RDP session for my customer. Any guidance on how to activate the discovery mode/add devices would be greatly appreciated.
  • Legacy Gateways & Energy Servers
  • troubleshooting
Romain_Polette
Kirk
Posted: ‎2024-01-18 01:03 AM
2460
Hi @ArcherWang ,
As mentioned by Guillaume, please first check that your PowerTag sensor front LED is blinking fast orange.
If not blinking orange, it means that the PowerTag sensor is not ready to be paired with Panel Server.
In this case:
  • If PowerTag sensor is blinking fast red, you need to power off/on the sensor to put it in pairing mode (blinking orange)
  • If PowerTag sensor is blinking slow red or slow green, it means that the sensor is paired with another gateway
Romain POLETTE
Solution Architect - France Operations
Guillaume_Evrard
Captain
Posted: ‎2024-01-22 08:48 PM
1
2435
Hello, I let @Romain_Polette answer but his previous answer seems to confirm that if the gateway has disappeared and not able to communicate with the gateway (blinking fast red) you have to power off/on to reset it and be able to pair to a new gateway.
If you can unpair it should allow to pair it without requiring reset,
Kind Regards
Romain_Polette
Kirk
Posted: ‎2024-01-23 12:15 AM . Last Modified: ‎2024-01-23 12:18 AM
2429
Hello @ArcherWang ,
My answers in red below.
"If a sensor has been previously paired with a PowerTag Link (PTL) and is now being replaced with a PAS600, should I unpair the sensors before scanning them with the PAS?"
=> Yes this is the best practice. But it can depend on your case...
=> Case 1: both PTL and PAS600 are on or PTL is on - PAS600 is off:
  • In this case the PowerTag sensors may be still paired with the PTL.
  • Check that the PTag sensors are blinking slow green (every 5 sec or more).
  • Open your PTL web services (or connect the PTL to EcoStruxure Power Commission (EPC)).
  • Unpair the PTag sensors from the PTL
  • Check that the PTag sensors are now blinking fast orange
  • You can pair the Ptag with your PAS600
=> Case 2 : PTL is off - PAS600 is on:
  • If the PTag sensors are blinking fast red it means that the sensors have lost the communication with the PTL for more than 300 sec (issue with gateway detected).
  • if both PTL and PAS600 are mounted on the same panel, you can try power on the PTL. Then, PTag sensors should retrieve the communication with PTL after 1 or 2 minutes (blinking slow green). Follow case 1 to unpair sensors from the PTL.
  • If the PTL was removed from the panel or if the PTag sensors are still blinking fast red, read my answer bellow
"Or is there a method to reset the sensors?"
=> You cannot "soft reboot" the PowerTag sensors (no front face button or restart feature integrated in the gateways). The only way to restart this sensor is to power it off/on (open/close the associate breaker). After a power off/on, the Ptag sensor should blink fast orange (ready for pairing process).
Romain POLETTE
Replies 7
Guillaume_Evrard
Captain
Posted: ‎2024-01-17 09:05 PM
Personaly I do not use EPC, I am using the web pages. Is the Zigbee wireless network activated on the PAS ?
Normally you should launch the discovery and pair your powertag locally. If the powertag was paired to the PTL you  might have to unpair/reset it if similar to other zigbee devices but I do not use them.
A9MEM1540 is in the release not since 1.3.2, so it is supported.
Maybe you have to check the Led indication on Powertag to identify the status.
Kind Regards
Romain_Polette
Kirk
2461
Hi @ArcherWang ,
In this case:
Romain POLETTE
ArcherWang
Posted: ‎2024-01-22 05:40 PM
2440
Thanks for your reply.
Thank you for your response.
In the second scenario, if a sensor had been previously paired with a PowerTag Link and is now being replaced with a PAS600, should I unpair the sensors before scanning them with the PAS? Or is there a method to reset the sensors?
Kind regards,
Archer
Guillaume_Evrard
Captain
1
2436
Kind Regards
Romain_Polette
Kirk
2430
Hello @ArcherWang ,
Romain POLETTE
ArcherWang
Posted: ‎2024-01-24 02:55 PM
Thank you very much for your response. I've been seeking detailed information because the PowerTags are connected to Circuit Breakers (CBs) in the main switchboard of a building. Rebooting the PowerTags would necessitate a brief power outage for the building, and I wanted to ensure that I have all the necessary information to coordinate this outage window effectively.
Kind regards,
Archer
Dayana_Herrera
Dayana_Herrera
Cadet
Posted: ‎2024-11-24 07:17 PM
Please in my project every time there is a power outage the power tags get disconnected from the pass 600L and do not reconnect automatically even though the PASS 600L does not turn off because it is backed up by UPS.
