ASCII Communication between a PLC & ASCII device through Link 150
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • ASCII Communication between a PLC & ASCII device through Link 150
Romain_Polette
Kirk Romain_Polette Kirk
116
Guillaume_Evrard
58
Randi_Dolan
46
Luckey1001731004
Luckey1001731004 Cadet
Cadet
Posted: ‎2023-06-19 12:34 AM
1088
Hi Team,
I am trying to communicate an ASCII supporting relay with my PLC through Link 150. PLC to Link 150 communication is working OK as I am receiving response from Link 50 to PLC but I am not sure about Link 150 to relay communication. Although I have set all the communication parameters as per requirement.
Point to be Note:- If I communicate the same relay with PLC directly over serial port, Communication is found OK. Response was correct. Issue is in EGX with Relay communication, Also I don't know how to check ASCII data over LINK 150 Web Page. Please suggest any solution.
  • Legacy Gateways & Energy Servers
  • troubleshooting
  • EGX 150
RobGraham
Commander RobGraham Commander
Commander
Posted: ‎2023-06-20 04:50 AM
Are you referring to Modbus ASCII?  If so, the Option should be under Serial Port->Transmission Mode, per the manual:
Once set, if the parameters are correct, you should be able to read registers from Diagnostics->Read Device Registers.
