TC903-4FMSA FCU Room Thermostat
Intelligent Devices Forum
Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
  • EcoStruxure Building
  • Intelligent Devices
  • TC903-4FMSA FCU Room Thermostat
CraigEl
Administrator CraigEl Administrator
42
MikaelKrantz
Guinan MikaelKrantz Guinan
11
Gary
Gary Schneider Alumni (Retired)
11
Back to Intelligent Devices Forum
Wyman_Yeung
Ensign Wyman_Yeung Ensign
Ensign
Posted: ‎2021-12-02 07:14 PM . Last Modified: ‎2021-12-09 12:43 AM
3379
We have a project using TC903-4FMSA and will using AO to control the FCU fan speed.
But the customer require TC903 thermostat to repeat the Fan status.
Can we use the DO point (dry contact) to represent the Fan running status?
What is the DO point used for?
Please refer to attached wiring diagram.
Thx for advise?
  • Thermostats
Replies 6
Gary
Posted: ‎2021-12-03 03:23 AM
3357
Hello Wyman,
Re: Please refer to attached wiring diagram.
I do not see any attachments?
Wyman_Yeung
Ensign
Posted: ‎2021-12-03 08:52 AM . Last Modified: ‎2021-12-03 08:54 AM
In response to Gary
3345
CraigEl
Posted: ‎2021-12-06 05:34 PM
In response to Wyman_Yeung
3332
Hi Wyman
I suspect that the ECM fan requires some sort of PWM control and that is why the DO is required.
Wyman_Yeung
Ensign
Posted: ‎2021-12-08 08:11 PM
In response to CraigEl
Well noted and many thx.
Posted: ‎2022-01-17 11:29 PM . Last Modified: ‎2022-01-18 08:24 PM
Thanks for sharing i was curious to know about it and this was true and solved my issue thanks for your support.
Myloweslife
PetZeri
PetZeri
Cadet
Posted: ‎2022-04-12 12:59 PM . Last Modified: ‎2022-04-12 01:02 PM
The advanced indoor regulator are only for room temperature control in 2-lines and 4-pipes FCU cooling frameworks with 3-speed fan and a couple of water valves. Highlights: - Designed for control a 3-speed fan and a couple of water valves with fan speed auto or manual change selectable.
