TC-907
Intelligent Devices Forum
Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
  • EcoStruxure Building
  • Intelligent Devices
  • TC-907
CraigEl
Administrator CraigEl Administrator
41
Troy_Wecker
Lieutenant JG Troy_Wecker Lieutenant JG
11
Gary
Gary Schneider Alumni (Retired)
11
MikaelKrantz
Kirk MikaelKrantz Kirk
11
Back to Intelligent Devices Forum
dvir
Commander dvir Commander
Commander
Posted: ‎2022-09-06 05:34 AM
2234
TC-907
I have a case of a TC900 unit that has an analog cold water valve (proportional) and a digital hot water valve (On / Off)
Which model of TC-907 series should I order?
And are there special settings for this?
DavidChild
Sisko DavidChild Sisko
Sisko
Posted: ‎2022-09-07 12:50 AM
In response to dvir
Hi @dvir
Follow this for the analogue output impedance:
https://community.se.com/t5/Building-Automation-Knowledge/What-is-the-TC900-Series-thermostat-analog...
May be best to go for a coil impedance of 1000 / 1500 ohms. Use 1 first, test it.
These have been used in the past in the UK:
https://www.sontay.com/en-gb/products/inputoutput-modules/io-input-output-modules/io-rm-relay-module...
IO-RM1-12DC SINGLE RELAY MODULE 12VDC
DavidChild
Sisko
Posted: ‎2022-09-06 05:54 AM
2229
Hi
They all look to be modulating for both heating and cooling.
You could you a 12v dc relay with high impedance coil for the heating.
dvir
Commander
Posted: ‎2022-09-06 06:27 AM
In response to DavidChild
2226
Hi, ok, thank you very much, I understood that there are differences between analog and digital... so you can use
TC907-3A4DPMSAB
And add a 12v dc relay to the output of the faucet?
Do you have a model that you recommend?
Thank you very much
DavidChild
Sisko
In response to dvir
Hi @dvir
