Suitable duct mountable temperature sensor for TC-300 (Except RS- 03)
Intelligent Devices Forum
Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
  • EcoStruxure Building
  • Intelligent Devices
  • Suitable duct mountable temperature sensor for TC-300 (Except RS- 03)
CraigEl
Administrator CraigEl Administrator
42
MikaelKrantz
Guinan MikaelKrantz Guinan
11
Gary
Gary Schneider Alumni (Retired)
11
Back to Intelligent Devices Forum
Danith
Crewman Danith
Crewman
Posted: ‎2021-03-18 04:28 AM
1604
Is there any other duct mountable temperature sensor that can is compatible with TC- 300 (other than the RS-03)?
I have found that STD 500-150 is 10k NTC as RS-03 will it be possible for me to use it with the TC-300?
Yi_HU
Yi_HU Schneider Alumni (Retired)
Posted: ‎2021-03-23 08:09 PM
RS-03 and STD500 are both using the NTC10K type3 sensing element, but the component - thermistors of these 2 references are different, it means there is some difference on the character .
Better to do some on-site testing before use it, because different characters(resistance  v temperature table) should impact the accuracy performance if connected to TC thermostat.
Yi_HU
