Join our "Ask Me About" community webinar on May 20th at 9 AM CET and 5 PM CET to explore cybersecurity and monitoring for Data Center and edge IT. Learn about market trends, cutting-edge technologies, and best practices from industry experts.
Register and secure your Critical IT infrastructure
Multi Sensor - Insight sensor to surface mounting
Intelligent Devices Forum
Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
  • EcoStruxure Building
  • Intelligent Devices
  • Multi Sensor - Insight sensor to surface mounting
CraigEl
Administrator CraigEl Administrator
37
Troy_Wecker
Lieutenant JG Troy_Wecker Lieutenant JG
11
Gary
Gary Schneider Alumni (Retired)
11
MikaelKrantz
Kirk MikaelKrantz Kirk
11
EcoStruxure™ Building Operation
Back to Intelligent Devices Forum
janim
Spock janim Spock
Spock
Posted: ‎2023-05-10 11:20 PM
2
1463
We need install Multi / Insight sensor to surface. There is no possibility to create hole to surface.
What kind adapter you are used in this kind case?
If it ain't broke, don't fix it.
HeleneZ
Crewman HeleneZ Crewman
Crewman
Posted: ‎2023-05-16 04:30 AM
1412
Hi Janim,
You can use a junction/mounting box. One example is the one that can be seen on the Installation sheet for the Multi-Sensor and Insight-Sensor. Unfortunately, we do not provide those accessories yet. What to think about is that the mounting ring that comes with the Multi- and Insight-Sensor fits on the junction/mounting box you choose. I would recommend you to look for a box at one of your local wholesale/retailer.
janim
Spock janim Spock
Spock
Posted: ‎2023-05-16 05:46 AM . Last Modified: ‎2023-05-16 05:47 AM
In response to HeleneZ
A box like that is not pretty, because it will also remain visible.
HeleneZ
Crewman
1413
Hi Janim,
janim
Spock janim Spock
Spock
This is a heading
