M700 change Spring return Direction
Intelligent Devices Forum
Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
  • EcoStruxure Building
  • Intelligent Devices
  • M700 change Spring return Direction
CraigEl
Administrator CraigEl Administrator
41
Troy_Wecker
Lieutenant JG Troy_Wecker Lieutenant JG
11
Gary
Gary Schneider Alumni (Retired)
11
MikaelKrantz
Kirk MikaelKrantz Kirk
11
Back to Intelligent Devices Forum
Hamid_Reza_Mobarakish
Lieutenant JG Hamid_Reza_Mobarakish
Lieutenant JG
Posted: ‎2021-03-11 01:18 AM . Last Modified: ‎2021-03-17 03:48 AM
3096
Dear All,
I bought M700-SRSU.I installed on VGS211F. Stem down is fully close  for VGS211.but the M700-SRSU is stem-up fully close.How can I change spring return direction.I want to convert it from SRSU to SRSD.
  • Traditional Valves and Actuators
CraigEl
Posted: ‎2021-03-11 09:48 PM . Last Modified: ‎2021-03-11 09:48 PM
3086
I don't believe that this is possible, the spring function is mechanical and cannot be altered. You should return the actuator and purchase the M700-SRSD
Replies 4
CraigEl
3087
Lieutenant JG
Posted: ‎2021-03-11 09:52 PM
In response to CraigEl
Ok.thank you for your reply
Simon_Firth
Lieutenant JG Simon_Firth Lieutenant JG
Lieutenant JG
Posted: ‎2021-03-12 06:08 AM
Correct Craig, it is not possible to convert an SRU to and SRD
Mr Valve
Simon_Firth
Lieutenant JG
Posted: ‎2022-02-28 02:16 AM
In response to Treutel365
The M700 SR actuator is also the replacement to the AL..S series actuator from Satchwell along with the L7SV linkage kit for the Satchwell valves listed.  As ever, attention is to be paid on selection to which direction the spring is set up to drive upon power failure, the actuator cannot be converted.
Mr Valve
