BACnet mstp or Modbus RTU Temp/Humidity Sensor
Intelligent Devices Forum
Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
  • EcoStruxure Building
  • Intelligent Devices
  • BACnet mstp or Modbus RTU Temp/Humidity Sensor
CraigEl
Administrator CraigEl Administrator
42
MikaelKrantz
Guinan MikaelKrantz Guinan
11
Gary
Gary Schneider Alumni (Retired)
11
Back to Intelligent Devices Forum
NicoleGonzalez
Lieutenant JG NicoleGonzalez Lieutenant JG
Lieutenant JG
Posted: ‎2021-05-26 01:59 PM
11
6449
We have been requested to monitor only approximately 30 hospital rooms for T/H and I would like to be able to daisy chain these back to the AS-P as an integration. I will also need to confirm the quantity we can support on one comm bus back to the AS-P.
Is there a Temp/Humidity Sensor that we can use with EBO that communicates via BACnet mstp or Modbus RTU? I have looked at the SE8000's and the SmartX sensors (Ethernet sensor Bus) but they are not ideal for the reasons below.
The SmartX Living Sensors could be an option but the quantity you can put on a daisy chain is up to 4 and limited to a 200' distance. Also I would need to include multiple MP or RP field controllers to support the sensor bus under the AS-P. That adds a good amount of cost.
The SE8000's could be an option but I really only need the T/H monitoring so if there's something without all the I/O that would be preferred.
Any insight on another device would be very much appriciated,
Nicole Gonzalez
Acct Exec
Chicago Buildings Branch
  • Temperature Humidity & Air quality Sensors
MikaelKrantz
Guinan
Posted: ‎2021-05-26 11:43 PM
6
6443
Does the SmartLogic SLP series help you?
klangton
Commander klangton
Commander
Posted: ‎2021-08-20 04:44 PM
In response to NicoleGonzalez
1
5947
I know this is late, but perhaps it will help someone else. These work well, and are easy to integrate:  CW2XP2A Veris CW2 Protocol Series Air Quality Sensor, CO2, Wall, Replaceable Humidity 2%, Temperature Transmitter, BACnet MSTP/Modbus. They are available through iportal.
Replies 11
MikaelKrantz
Guinan
6
6444
NicoleGonzalez
Lieutenant JG
Posted: ‎2021-05-27 04:54 AM
In response to MikaelKrantz
6437
@MikaelKrantz
I'm unfamiliar with these (or atleast I believe I am). A google search came up with no results. Can you share a link to these or a model # I can better identify these from?
Thank you,
Nicole
Nail
Nail Schneider Alumni (Retired)
Posted: ‎2021-05-27 05:06 AM
3
6432
SpaceLogic SLP Series Humidity Sensors (temperature included) https://ecoxpert.se.com/search?documentUUID=10d66b41-5e87-49fc-9084-83f04e647fa7&title=SpaceLogic%20...
MikaelKrantz
Guinan
Posted: ‎2021-05-27 05:20 AM
Think you should be able to find some info about them if you search for "SLPSTX2" on Exchange or maybe on the Internet.
Please note that I have not used them myself,
NicoleGonzalez
Lieutenant JG
Posted: ‎2021-05-27 05:33 AM
In response to Nail
2
6429
@MikaelKrantz @Nail
   Thank you, I was unaware these existed and look like a viable solution!
Very much appriciated,
Nicole
klangton
Commander klangton
Commander
1
5948
NicoleGonzalez
Lieutenant JG
Posted: ‎2021-08-21 06:39 AM
In response to klangton
@klangton Great info, thank you!!
DavidChild
Sisko DavidChild Sisko
Sisko
Posted: ‎2021-08-21 09:46 AM
5939
Have you looked at the SpaceLogic SLP sensors:
https://iportal2.schneider-electric.com/Contents/docs/SPACELOGIC%20SLP%20SERIES%20HUMIDITY%20SENSORS...F
NicoleGonzalez
Lieutenant JG
Posted: ‎2021-08-23 07:39 AM
In response to DavidChild
@DavidChild wor, nice! Thank you for adding these into the conversation!
janim
Spock janim Spock
Spock
Posted: ‎2021-08-30 04:06 AM
Do you have Smart Widget files to Modbus and BACnet devices?
If it ain't broke, don't fix it.
Michael_Jensen
Lt. Commander Michael_Jensen Lt. Commander
Lt. Commander
Posted: ‎2024-06-19 01:44 PM
Adding to this chain that SpaceLogic SLP Series sensors Modbus Custom Types are available to use inEBO 5.x and later, the link to the BMS Applications > Modbus Applications, use Room Sensors filter on the left:
Schneider - BMS Applications - https://bms-applications.schneider-electric.com/type/MB
