This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
Posted: 2025-04-08 12:01 AM . Last Modified: 2025-04-08 12:10 AM
After upgrade to ver. 1.14.2 I get an error when trying to reach the Custom folder under Script. When press "reload" I come back to the standard folder but it seems impossible to open the Custom folder without an error.
I've tried to reinstall the application and log in/out but still same behavior. See attached image.
When running software on a NON-SE laptop it works okay
Posted: 2025-04-08 12:08 AM
Strange - what if you try to remove the scripts you have imported to custom ?
They are located in your Documents folder under 'Documents\Seal\Utilities\Script'
Posted: 2025-04-09 03:01 AM
It seems to have been related to a "Multibinder" Script. When that was removed it was working
Posted: 2025-04-09 05:26 AM
Ok, could you perhaps send me the script that caused the issue so we see if we can prevent this to happen in the future.
