SEAL / EBO BACnet Alarms problems
EcoStruxure SEAL Forum
This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
Showing results forΒ
Did you mean:Β
  • EcoStruxure Building
  • EcoStruxure SEAL Forum
  • SEAL / EBO BACnet Alarms problems
StefanLundin
Commander StefanLundin Commander
35
Benji
Administrator Benji Administrator
16
Jim.T
Lieutenant JG Jim.T Lieutenant JG
5
APA
Lieutenant APA Lieutenant
4
Back to EcoStruxure SEAL Forum
JohnnyCarlsen
Lieutenant JohnnyCarlsen Lieutenant
Lieutenant
Posted: β€Ž2025-04-07 12:38 AM . Last Modified: β€Ž2025-04-08 03:52 AM
591
I want to change BACnet Alarm from "Floating to Out of range", but can not make it work. 😞
If I delete BACnet object "bacnet.pt.eventparameters.FL" and create an new
"bacnet.pt.eventparameters.OOR" it look fine from SEAL but then at open properties on the BACnet Alarm, it still is an Floating Alarm and the "Save Disk" appears. Are there some properties in the BACnet object there has to be changed to ??
CODE:
if(object.typeName.match("bacnet.pt.eventparameters.FL")) {
            // Floating BACnet alarm
            const result = await sdkClient.IObjectManagement.DeleteObject({ objectPath: object.fullPath}) // Delete Floating alarm
            if(!result.failed) {
                // Change name
                const newname =  object.fullPath.replace("Floating limit event parameters","Out of range event parameters")
                // Create Out of range BACnet alarm
                await sdkClient.IAdvanced.CreateObject({path : newname , typeName: "bacnet.pt.eventparameters.OOR", isAggregated: true, isHidden: true })
OUTPUT:
IObjectManagement.DeleteObject: Operation executed successfully! Status: Ok Path: /RPC/BACnet Interface/IP Network/RPC/Application/RPC/Alarmer/TE001_A/Floating limit event parameters
IAdvanced.CreateObject: Operation executed successfully! Status: Ok Path: /RPC/BACnet Interface/IP Network/RPC/Application/RPC/Alarmer/TE001_A/Out of range event parameters
ISession.Save: Operation executed successfully! Status: Ok
RESULT;
  • Script
MikaelBodereau
Lieutenant MikaelBodereau Lieutenant
Lieutenant
Posted: β€Ž2025-04-08 12:54 AM
531
Hi Johnny,
I tested with same issue. After some tests i found that YOU MUST ALSO change 'EventType' property.
Like :
res=await sdkClient.IObjectManagement.DeleteObject({objectPath:'/GSVA11_S06000/BACnet Interface/Application/BACnet Alarm/Out of range event parameters'})
res=await sdkClient.IAdvanced.CreateObject({path:'/GSVA11_S06000/BACnet Interface/Application/BACnet Alarm/Floating limit event parameters',typeName:'bacnet.pt.eventparameters.FL',isHidden:true})
res=await sdkClient.IAdvanced.SetPropertyValue({propertyPath:'/GSVA11_S06000/BACnet Interface/Application/BACnet Alarm/EventType',value:new Long(4)})
await sdkClient.ISession.Save()
MikaelBodereau
Lieutenant
532
Hi Johnny,
Like :
JohnnyCarlsen
Lieutenant
Posted: β€Ž2025-04-08 02:51 AM
In response to MikaelBodereau
Thanks Mikael, it was just what I needed πŸ‘πŸ˜€. In my case EvenType has to be 5 of "Out of range"
Β
