This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
Posted: 2025-04-09 05:19 AM
Thanks for reporting. Yes there was an issue with the Swedish naming convention when a multiple combination of MultiFunctional sensors and Bus sensors where used.
An updated version of Connected Room Solution is now published (5.1.6) but you will need to shorten the 'GT_GX_21544' to be able to download the FB correct , otherwise you will reach the max limit of characters that the FB supports. I tried your solution with GA21544 and that worked. ( GAxx being the new standard naming for sensors with multiple functions )
Posted: 2025-04-09 07:18 AM
Tack! Snabba ryck som vanligt :).
Jaha det var en ny standard i BIP t.o.m. Tack för info!
