Support for Edge-Server/ES/EC
EcoStruxure SEAL Forum
This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
  • EcoStruxure Building
  • EcoStruxure SEAL Forum
  • Support for Edge-Server/ES/EC
StefanLundin
Commander StefanLundin Commander
35
Benji
Administrator Benji Administrator
20
Jim.T
Lieutenant JG Jim.T Lieutenant JG
5
Back to EcoStruxure SEAL Forum
LukasB
Ensign LukasB Ensign
Ensign
Posted: ‎2025-01-13 07:05 AM
4
1032
Are there any plans on adding support for connecting SEAL to edge servers etc?
Tried to connect with a test edge server and edge enterprise server but I get an error msg.
  • Design
  • Swedish
Benji
Posted: ‎2025-01-15 01:56 PM
In response to LukasB
@LukasB this has now been added to the backlog. Thanks!
StefanLundin
Commander
Posted: ‎2025-02-12 05:52 AM
@LukasB Seal 1.13 with support for CS/ES/EC EdgeServer is now released
Replies 4
Benji
Posted: ‎2025-01-13 05:03 PM . Last Modified: ‎2025-01-13 05:03 PM
1003
@LukasB  SEAL as such has no issue connecting. However, a given application/database has to support a given server type.
A database/application will typically be connected to hardware. There can of course be cases where everything is located outside the AS.
Is the use case here engineering of RP/MP controllers connected over IP to an EdgeServer?
There shouldn't really be any big technical constraint, but I'd like to understand the use case.
LukasB
Ensign
Posted: ‎2025-01-13 09:27 PM
In response to Benji
990
Sounds fair.
One of the main use cases would be rp/mp controllers yes.
Different interfaces such as modbus tcp, bacnet and mqtt to connect devices situated in buildings where we do not have avalible servers to host the device.
We have limitations on deploying interfaces directly on the ES, not technical, rather strict guidlines. It would be great to deploy an edge-server under the ES to host said things and be able to connect via SEAL to simplify my work.
Benji
StefanLundin
Commander
