PCT 2.0 Packages 5.x.x.x connection with Seal error
EcoStruxure SEAL Forum
This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
  • EcoStruxure Building
  • EcoStruxure SEAL Forum
  • PCT 2.0 Packages 5.x.x.x connection with Seal error
StefanLundin
Commander StefanLundin Commander
35
Benji
Administrator Benji Administrator
20
Jim.T
Lieutenant JG Jim.T Lieutenant JG
5
Back to EcoStruxure SEAL Forum
MikaelBodereau
Lieutenant MikaelBodereau Lieutenant
Lieutenant
Posted: ‎2025-02-12 03:14 AM
1016
Hi Seal community,
Today i'm trying to use seal script with an ASP on PCT2 and i have an access error. After many tests i found that i can access with ASP version 4, version 6, version 3 on PCT 2.0 but not V5 (all ASP on V5 is failed).
Has someone have an idea to fix it?
Access by workstation is OK.
same by seal :
  • Script
StefanLundin
Commander
Posted: ‎2025-02-12 03:24 AM
1013
Hi Mikael,
By the message you get, it looks like you perhaps are missing a hotfix for your workstation.
The Release notes for PCT 2 tells you that you must install EBO workstation hotfix 5.0.3.5001-CP4 or later to work with PCT2. The corresponding Hotfix needs to be installed if you are using older versions of EBO Workstation as well.
StefanLundin
Commander
1014
Hi Mikael,
MikaelBodereau
Lieutenant
Posted: ‎2025-02-12 04:22 AM . Last Modified: ‎2025-02-12 04:22 AM
New tests, i upgraded V5.0.3 to 6.0.3, now i can access to this ASP !!!
MikaelBodereau
Lieutenant
Posted: ‎2025-02-12 11:24 PM
In response to StefanLundin
Hi Stefan, you're right my workstation is not at the good version, hotfix fixes it. I'm surprise because in my mind i've done for V6 and V5 in the same time. Maybe i need to seal script my brain. Thanks a lot.
