This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
Posted: 2025-02-04 12:19 AM . Last Modified: 2025-02-04 12:22 AM
Hi
I am using Seal version 1.12.1.1 and is having problem with getting all layers converted.
In Autocad I have the Layer L-HAT-CONC which are the solid walls showing here:
I convert the drawing with these settings
After conversion the Layer is not in the file and the concrete is missing.
Any idea, why this is happening, and can it be solved ?
Attached are both the source file and the converted file.
Posted: 2025-02-12 12:12 AM
I did a quick peek and it is the HATCH element that we do not currently support you are looking for.
Support for HATCH was not included in the initial release as it is a more complex element.
A limitation to think about is that a HATCH can have solid or pattern fill, in our case only solid fill can be represented in a good way in TGML.
This feature request is added to the backlog as 18160 in the system.
Posted: 2025-02-04 05:02 AM
Added as defect 18102 in our system
Posted: 2025-02-06 01:28 AM
Just guessing here, this is probably a Hatch DWG element, those elements have a tendency to require lots of elements to be represented in TGML even if when they look simple.
We will take a quick look at the file next week.
