Dwg2Tgml conversion problem
EcoStruxure SEAL Forum
This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
  • EcoStruxure Building
  • EcoStruxure SEAL Forum
  • Dwg2Tgml conversion problem
StefanLundin
Commander StefanLundin Commander
35
Benji
Administrator Benji Administrator
19
Jim.T
Lieutenant JG Jim.T Lieutenant JG
5
Back to EcoStruxure SEAL Forum
FlatBeach
Sisko FlatBeach Sisko
Sisko
Posted: ‎2025-01-26 11:49 PM
1184
I am using Dwg2Tgml and is having problems with the outcome.
The problem is that the outcome doesn't look like the source file. The building gets another shape.
It looks wrong already in the preview inside Dwg2Tgml
I have tried saving the source in 2010 format before the converting. That didn't help.
The source looks right in AutoCad and DWG Trueview.
Any idea what to do?
I have attached the source file and the outcome if anyone would like to see what is wrong.
Etageplaner - E2 - Kun skal.tgml
Etageplaner - E2 - Kun skal.dwg
  • Dwg2Tgml
MortenEnger
Lieutenant MortenEnger Lieutenant
Lieutenant
Posted: ‎2025-01-28 12:59 AM
3
1111
The issue was with handling of large arc flag, this is now corrected and will be released with the next version of SEAL.
Replies 5
MortenEnger
Lieutenant
Posted: ‎2025-01-26 11:57 PM
I will take a look at this in the next few days
MortenEnger
Lieutenant
3
1112
FlatBeach
Sisko
Posted: ‎2025-02-04 12:23 AM
In response to MortenEnger
1044
When do you expect next version to be released ?
Benji
Posted: ‎2025-02-04 12:37 AM
In response to FlatBeach
Very shortly 🙂
MortenEnger
Lieutenant
Posted: ‎2025-02-07 04:46 AM
SEAL 1.13.0 that solves this issue is expected to be released early next week.
