Search and Replace 3.5.3 - [Error] Editing Function Block Program variables.
EcoStruxure SEAL Forum
This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
  • EcoStruxure Building
  • EcoStruxure SEAL Forum
  • Search and Replace 3.5.3 - [Error] Editing Function Block Program variables.
StefanLundin
Commander StefanLundin Commander
35
Benji
Administrator Benji Administrator
20
Jim.T
Lieutenant JG Jim.T Lieutenant JG
5
EcoStruxure SEAL
Back to EcoStruxure SEAL Forum
PhilipTM
Crewman PhilipTM
Crewman
Posted: ‎2025-08-28 08:35 AM
660
When using the S&R script, the script had a problem with editing Function block program Variables and Const. The pasted log is from running script again after a successful S&R of all the other areas.
Hope it's enough to explain if i did something wrong or if this is a common problem with this S&R version.
  • Script
Replies 5
StefanLundin
Commander
Posted: ‎2025-08-28 12:31 PM
Hi Philip, It's hard to tell what goes wrong just by looking at your logfile.
One thing to consider is ensuring that search and replace operations do not result in object names or constants exceeding the length permitted by EBO, and that no invalid characters are used.
The script is quite raw in this regard and does not have built-in controls to prevent such syntax errors.
Benji
Posted: ‎2025-08-28 01:06 PM
644
@PhilipTM if you provide an export, what you search for and what you enter in replace, we can check.
JohnnyCarlsen
Lieutenant JohnnyCarlsen Lieutenant
Lieutenant
Posted: ‎2025-08-28 10:13 PM
594
@PhilipTM  You can try and use Search And Replace Turbo, it will might tell you what is going wrong with renaming in FBP. You find S&R Turbo in this forum
PhilipTM
Crewman PhilipTM
Crewman
Posted: ‎2025-08-28 11:19 PM
In response to Benji
I don't know how much i can share. But seems like it has something to do with the length of the renaming. I'll try out some different iterations of the "From - To" csv. to see if i can find what names are the problem, and then return.
PhilipTM
Crewman PhilipTM
Crewman
Posted: ‎2025-08-29 02:26 AM
In response to JohnnyCarlsen
@JohnnyCarlsen Thx for suggestion and taken the time to support. For now since i think it's a "User Error"/me using tool incorrectly. I'll just stay with the version that is installed and on current Seal Version installed on our server. To narrow down step by step the mistakes made.
