This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
Posted: 2025-05-15 02:55 AM
Hi!
I'm developing a script that makes thousands of calls to sdkClient.IAdvanced.SetPropertyValue. I've noticed a significant performance issue:
Value parameter (a VariablesPropertyReference) points to an existing server, the call completes in 3-5ms, even if that server is offline/unreachable.Value parameter points to a non-existent server, the call takes approximately 4500ms.For example, with this structure:
ES
--Servers
----AS01
----AS02
My script needs to make thousands of these calls, potentially referencing about 20 different servers. In a test environment, I don't have that many actual physical test servers that i can name to match all the production server names.
I guess i could setup those servers in PCT to match the names of the real production environment, but it seems like a very tedious task to do and there should be a better alternative.
When running against non-existent servers, this adds multiple hours to the execution time, which is not feasible for testing.
Is there a way to improve performance when the script references non-existent servers?
I'm looking for solutions that don't require:
Has anyone encountered this issue before? Are there any configuration settings, caching mechanisms, or alternative approaches that could help reduce the execution time when referencing non-existent servers?
I understand that this limitation is probably within the SDK/API itself, and not a actual "SEAL-problem".
Any suggestions would be greatly appreciated!
Posted: 2025-05-15 06:55 AM
Posted: 2025-05-15 08:41 AM
Don't know if it would be feasible to do a getchild for /Servers at the start, create a List<string> and then only run updates for any paths starting with a string in the list... just an idea (but I assume you already thought of that :-))
