Script on prefix
EcoStruxure SEAL Forum
This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
  • EcoStruxure Building
  • EcoStruxure SEAL Forum
  • Script on prefix
StefanLundin
Commander StefanLundin Commander
35
Benji
Administrator Benji Administrator
20
Jim.T
Lieutenant JG Jim.T Lieutenant JG
5
Back to EcoStruxure SEAL Forum
Mads_Balsgaard_DK
Crewman Mads_Balsgaard_DK Crewman
Crewman
Posted: ‎2025-05-01 10:51 PM
1501
Script on prefix
Hi, can a script be made for prefix, so that prefix is ​​named folder name or folder folder name followed by a special character ?
  • Script
Replies 9
erik_ogren_cbkab
Ensign erik_ogren_cbkab
Ensign
Posted: ‎2025-05-04 11:08 PM
2
1462
I have been requesting a simular function for like 6 years!
Although not a script but a substitution code. Something for a relative sourcename (like a folder.).
In case of multiple type-rooms or custom types, it would be extremely useful to use the folder name as a Prefix for the alarms.  Something like this for example (@SourceName(../../)). In other words; A substitution code for a relative sourcename.
Another request I have had, but not totally different, is a subustution code for DeviceName. Today we have this option:
If this also included Modbus and BACnet devices it would also be very, very helpful when setting prefixes to  multiple VAV/Fire dampers. It's not unusual we set them up in the hundreds!
If we get the relative SourceName prefix, the DeviceName prefix is no longer necessary though!
A man can dream, hopefully less than a decade 😉
JohnnyCarlsen
Lieutenant JohnnyCarlsen Lieutenant
Lieutenant
Posted: ‎2025-05-05 09:55 PM
Yes, I have just made one for at specific setup, so it can of course also be modified too your project.
Benji
Posted: ‎2025-05-07 12:29 AM
1
1412
@APA is this something that the "ADVANCED - Alarm Message and prefix setter" would handle? Just thinking about adding it to our initiative.
@StefanLundin
NiilaM
Lieutenant NiilaM Lieutenant
Lieutenant
Posted: ‎2025-05-07 06:15 AM
In response to erik_ogren_cbkab
I have similar request as well, this kind of functionality is very much needed.
Custom Alarm Substitution Codes - Schneider Electric Community
@Mads_Balsgaard_DK , I think what you want is possible to do with our CSV To Prop-script with a little Excel magic. If needed I can help you with that. 🙂
Solved: CSV to Prop script. Edit multiple objects and properties using Excel. - Schneider Electric C...
JohnnyCarlsen
Lieutenant
Posted: ‎2025-05-07 11:08 PM
1
1376
You can try an use my "AlarmPrefix change from Path". Use regex to extract the part of the path you want to use in Prefix. Add parts with "-" and ends with "-" plus user start Prefix if needed.
AlarmPrefix change form Path name-1.1.0.zip
Mads_Balsgaard_DK
Crewman
Posted: ‎2025-05-07 11:55 PM
Yes exactly... I hope this is incorporated into future versions of EBO... I spend so much time correcting prefixes.
APA
Lieutenant APA Lieutenant
Lieutenant
Posted: ‎2025-05-14 02:23 AM
In response to Benji
That one is a bit dated and unfortunately no, it cannot set prefix using the path.... just edit the existing one with regex.
FilipSteijner
Ensign FilipSteijner Ensign
Ensign
Posted: ‎2025-05-15 01:15 AM
@Mads_Balsgaard_DK Did you find a solution for this? Otherwise it seems like a very simple script can accomplish this, you can contact me if you need help creating one.
JohnnyCarlsen
Lieutenant
Posted: ‎2025-05-15 09:52 PM
In response to JohnnyCarlsen
I discovered an error in my SEAL Script, so please this new one instead
Set AlarmPrefix form Alarm Path-1.1.2.zip
