This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
Posted: ‎2025-10-17 11:49 PM . Last Modified: ‎2025-10-17 11:50 PM
PCT2 and SEAL should work just fine. And yes, you should use non-secure communication—I have that setup on my machine.
There were some EBO/PCT2 combinations (prior to EBO 6.0) that required a workstation hotfix, according to the PCT2 release notes. If that wasn't fulfilled Seal could not setup a communication.
Please check this link if that applies to your case:
https://community.se.com/t5/EcoStruxure-SEAL-Forum/Connecting-to-PCT-server-issue/m-p/507217#M262
Posted: ‎2025-10-18 03:04 AM
@Adam_Tri-M thanks for playing with SEAL 🙂 As @StefanLundin notes, it most definitely works with PCT. In the thread @StefanLundin is linking to, I've shared a document created by the GEC team: https://community.se.com/t5/EcoStruxure-SEAL-Forum/Connecting-to-PCT-server-issue/m-p/507235/highlig...
Please feel free to share anything you work with or come across
Posted: ‎2025-10-18 05:53 AM
I didn't think to remove the full https:\\ - i was changing it to just http:\\ in the address field.
But my other issue was that our PCT2 server has a DNS name we normally use to connect to.
However, my guess is the SEAL (and AET) cannot resolve that name.
Once I used the actual IP Address, I was able to connect.
Thanks all!
And again - this tool looks awesome. Creating a new script to do some auto binding as we speak!
Posted: ‎2025-10-19 11:59 PM
Nice!!!
Posted: ‎2025-10-22 02:16 AM . Last Modified: ‎2025-10-22 02:17 AM
Secure connection works with PCT2, you need to have the certificate installed to PCT2. After that the secure connection works, and you don't have to generate certificates in EBO Servers.
I have FQDN certificate installed on PCT2 and pct2.local points to 192.168.10.2 on my hosts file.
Posted: ‎2025-10-22 04:54 AM
If memory serves, I tried to do that, but my IT department didn't want to go thru the hassle of getting a 256 certificate - the normal ones are 512. Again - if I remember correctly.
