Dwg2Tgml - Window is reacting in strange way when moved around
EcoStruxure SEAL Forum
This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
  • EcoStruxure Building
  • EcoStruxure SEAL Forum
  • Dwg2Tgml - Window is reacting in strange way when moved around
StefanLundin
Commander StefanLundin Commander
35
Benji
Administrator Benji Administrator
16
Jim.T
Lieutenant JG Jim.T Lieutenant JG
5
APA
Lieutenant APA Lieutenant
4
Back to EcoStruxure SEAL Forum
FlatBeach
Sisko FlatBeach Sisko
Sisko
Posted: ‎2025-10-21 04:30 AM
3
79
Seal version : 1.17.2
Please take a look at the attached file.
Why us the content of the window not following the window when I move it around ?
  • Dwg2Tgml
StefanLundin
Commander
Posted: ‎2025-10-21 09:07 AM . Last Modified: ‎2025-10-21 11:30 PM
Hi @FlatBeach, thank you for reaching out.
I agree — that’s a really strange effect; I haven’t seen that before!
Correct me if I’m wrong, but did the SEAL window also shrink to a smaller size when you clicked the Add Files button (around 3 seconds in)? Or was that just an artifact of the screen recording?
Also, does this screen movement issue occur every time you try this — even before opening a file? And does it behave the same way across all SEAL utilities?
StefanLundin
Commander
Posted: ‎2025-10-21 11:47 PM . Last Modified: ‎2025-10-22 12:02 AM
1
37
I can now recreate it — it occurs when display scaling is enabled in your system settings.
We’ll look into this further.
Internal reference ENX-12066
Thanks again for reporting the issue!
FlatBeach
Sisko
Posted: ‎2025-10-22 05:04 AM
In response to StefanLundin
Great you found out why I got a strange behavior.
I have only tested it in Dwg2Tgml, since that is the only part of SEAL i use
