Continue
  • My Subscriptions
  • Events
Change Point Type From Current to Votage
EcoStruxure SEAL Forum
This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
  • EcoStruxure Building
  • EcoStruxure SEAL Forum
  • Change Point Type From Current to Votage
Benji
Benji Champion
63
StefanLundin
StefanLundin Champion
57
Jim.T
Jim.T Troubleshooter
5
Back to EcoStruxure SEAL Forum
arlena
arlena
Troubleshooter
Posted: ‎2025-07-25 08:50 AM
2750
It is very cumbersome to change point types from voltage to current or from current to voltage.
Given that Prometheus has the bizarre tendency to create all non temperature Analog Inputs as current and all Analog outputs as voltage, it would be handy to change that in Seal.
  • SEAL
Adam_Tri-M
Adam_Tri-M
Champion
Posted: ‎2025-10-20 08:37 AM
In response to StefanLundin
1
2391
Ah ha!!! Thank you @StefanLundin & @Benji !!!!!!
I was trying to use IAdvanced.SetUnit not the correct IAdvanced.ConfigureUnit
See attached 0.1.4 version which now restores units. This also will update the electrical range to 0-5V or 4-20mA.
Change IO type-0.1.4.zip
Replies 11
Benji
Benji Champion
Champion
Posted: ‎2025-08-05 05:35 AM
2689
This would definitely be possible to achieve with a SEAL Script.
arlena
arlena
Troubleshooter
Posted: ‎2025-08-06 06:05 AM
In response to Benji
2683
Would I be able to twist your arm into tackling such an endeavor?😀
Benji
Benji Champion
Champion
Posted: ‎2025-08-07 01:32 AM
In response to arlena
As you're actually changing the object type, the operation (under the hood) includes deleting the object, creating the new object, setting the properties and restoring the bindings... so not that simple, but of course doable.
@APA have you come across this before?
Benji
Benji Champion
Champion
Posted: ‎2025-08-07 03:05 AM
2676
@arlena this is a simple test using a lot of code from other scripts mainly from @APA - should give you an idea.
Change IO type-0.0.1.zip
Adam_Tri-M
Adam_Tri-M
Champion
Posted: ‎2025-10-19 02:15 PM
3
2483
I took this script and updated it a bit! Made it such that you can select to convert to either Voltage/Current/Temperature for either IO Modules or for MP/RP Controllers.
Two issues I haven't fixed yet:
1) The scaling isn't auto-updated, so that has to be manually done.
2) I cannot for the life of me figure out how to grab the unit of the value and then set it back to that. This tool just sets it to Volts/mA/°C.
I've tried the "await sdkClient.IAdvanced.GetUnit( {propertyPath: path2 + "/Value"} );" and "await sdkClient.IConfigureProperty.SetUnit({propertyPath : path2,   unit : desiredUnit})".
but neither works. Unsure for setting how it would even be encoded - just typing it out nor using the code from an XML export worked.
@Benji any idea on this one?
Eventually I would like to be able to do multiple inputs at once, I'll work on that after I figure out the units!
Change IO type-0.1.2.zip
Benji
Benji Champion
Champion
Posted: ‎2025-10-19 11:57 PM
In response to Adam_Tri-M
@Adam_Tri-M IAdvanced.GetUnit() is the right method, but units are a bit... special in EBO.
A unit is not a text, but an object like this:
var millimeterUnit = PrefixedUnit.Create(SIUnitPrefix.Milli, Unit.Length_m);
I'll check the script, but maybe @APA , @JohnnyCarlsen or @Jim.T have an idea
Benji
Benji Champion
Champion
Posted: ‎2025-10-20 12:30 AM
2452
I got the prefix and unit out like this:
  const { returnValue: unitResult, status } = await sdkClient.IAdvanced.GetUnit({propertyPath: originalObject.fullPath + "/Value"});
  sealScript.log("Getting Unit");
  sealScript.log(unitResult.prefix + ' ' + unitResult.unit);
Adam_Tri-M
Adam_Tri-M
Champion
Posted: ‎2025-10-20 05:51 AM
Getting there! I know get the unit.
Still can't figure out the creation/setting the unit.
No matter what i try, the "PrefixedUnit.Create..." command just returns [object Object].
async function setUnitOnValue(path2,origUnitprefix,origUnit) {
    const desiredUnit = PrefixedUnit.Create({SIUnitPrefix: "None", Unit: "Temperature_F"});
    sealScript.log(`${desiredUnit}`)
    const unitSettoValueResult = await sdkClient.IConfigureProperty.SetUnit({
        unit : desiredUnit
    if(unitSettoValueResult.failed){
        sealScript.alert(`Could not set unit on Value`);
    } else {
        sealScript.alert(`Unit Set Successfully`);
Tried passing the units I got from the original object, but that didn't work either. Guessing I don't have the PrefixedUnit.Create formatted correctly.
StefanLundin
Champion
Posted: ‎2025-10-20 08:06 AM . Last Modified: ‎2025-10-20 08:25 AM
2395
Hi @Adam_Tri-M
If you're still stuck on creating or setting the unit, it might be worth checking out our DemoScripts pack. It's a collection of example scripts designed to support script developers with various tasks in SEAL Script. One of the demos is Demo-Write Value with Unit, which could be relevant for your use case.
The DemoScripts aim to provide useful guidance on how to approach different scripting scenarios, and might help point you in the right direction for specific tasks.
You can download the full set from this post:
https://community.se.com/t5/EcoStruxure-SEAL-Forum/SEAL-Script-Editor-release-1-15/td-p/511553
As defined in the Demo Script the correct call would be : PrefixedUnit.Create("None", "Temperature_F");
The PrefixedUnit.Create function expects either:
  • Two string arguments: unitPrefix and unit, like PrefixedUnit.Create("Kilo", "Power_W")
  • Or just one string argument if no prefix is needed: PrefixedUnit.Create("Power_W")
Adam_Tri-M
Adam_Tri-M
Champion
1
2391
Benji
Benji Champion
Champion
Posted: ‎2025-10-20 01:30 PM
Nice! Thanks a ton for sharing this with the Community!
