SEAL Script: Set AlarmPrefix from Alarm Path
EcoStruxure SEAL Forum
This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
  • EcoStruxure Building
  • EcoStruxure SEAL Forum
  • SEAL Script: Set AlarmPrefix from Alarm Path
StefanLundin
Commander StefanLundin Commander
35
Benji
Administrator Benji Administrator
18
Jim.T
Lieutenant JG Jim.T Lieutenant JG
5
Back to EcoStruxure SEAL Forum
JohnnyCarlsen
Lieutenant JohnnyCarlsen Lieutenant
Lieutenant
Posted: ‎2025-05-15 10:43 PM . Last Modified: ‎2025-05-23 01:59 AM
1
498
SEAL Script to Set AlarmPrefix from Alarm Path.
This Script will set alarmprefix with part from alarm path. Use Regex to determine how part (Groups) you want to use for the AlarmPrefix.
It is possible to specify the Prefix and what text/string the Regex Groups should be joined with, and the Suffix.
Features:
  • Find alarms and view Prefix:
  • Find alarms and Set Prefix
  • Find regex in Alarm path: VEN\/(\w+)\/Room(\w+)
  • Join Regex Groups with: =
  • Prefix: SE-
  • Suffix: -
    This Script work only with Regex Groups ( ).
    E.g in below alarm you want VEN01 and room number in Prefix.
    AS01/VEN/VEN01/Room1005/Alarms/TT01_A
    Regex could look like this. /VEN\/(\w+)\/Room(\w+)/
                                                    Group1      Group2
    ' Prefix ' + Group1 +' Join Groups with '+ Group2 +' Suffix '
    Result: SE-VEN01=1005-
Need help with Regex? Try www.regex101.com
Set AlarmPrefix form Alarm Path-1.1.4.zip
  • Script
  • Shared Scripts
  • AlarmPrefix
JohnnyCarlsen
Lieutenant
Posted: ‎2025-05-23 02:01 AM
New version uploaded v1.1.4. Found a error in script, if using "|" in Regex
