SEAL Design : "Warning : Unit or ValueType mismatch..."
EcoStruxure SEAL Forum
This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
  • EcoStruxure Building
  • EcoStruxure SEAL Forum
  • SEAL Design : "Warning : Unit or ValueType mismatch..."
StefanLundin
Commander StefanLundin Commander
35
Benji
Administrator Benji Administrator
20
Jim.T
Lieutenant JG Jim.T Lieutenant JG
5
Back to EcoStruxure SEAL Forum
StefanLundin
Commander
Posted: ‎2025-02-19 03:43 AM . Last Modified: ‎2025-02-19 03:45 AM
Due to an unfortunate application library update to prepare for the upcoming Parts layer in Design, some users have reported receiving a warning when opening a solution created using a previous version of a library. The warning is looking somewhat like this:
We sincerely apologize for any inconvenience this may have caused. If you get this warning, we can fix this issue for you so you do not need to reconfigure your IO in your solution. Please send me a private message with your solution file, and we will ensure that your solution file is fixed and sent back to you.
The affected solutions is solutions based on Connected Room Solution, or some of the Swedish Libraries.
Stefan
  • Announcements
  • Design
Replies 0
