SEAL 1.12 Release!
EcoStruxure SEAL Forum
This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
  • EcoStruxure Building
  • EcoStruxure SEAL Forum
  • SEAL 1.12 Release!
StefanLundin
Commander StefanLundin Commander
35
Benji
Administrator Benji Administrator
20
Jim.T
Lieutenant JG Jim.T Lieutenant JG
5
Back to EcoStruxure SEAL Forum
StefanLundin
Commander
Posted: ‎2024-12-10 07:11 AM . Last Modified: ‎2025-01-15 12:11 AM
4
2527
SEAL 1.12 Release!
We are thrilled to announce the release of Standard Engineering Application Library 1.12, packed with new features and improvements to enhance your workflow and ensure seamless integration with EBO servers. For a detailed list of all the new features and improvements, please check out the full release notes.
This update includes automatic synchronization, advanced filtering options, and the highly anticipated autosave feature in SEAL Design. Additionally, we are introducing the brand-new SEAL Template Library, providing a centralized repository for system integration templates also including new filtering capabilities for the library view.
Key Highlights for SEAL Design:
  • AutoSave: Prevent data loss with our new autosave feature. If SEAL Design is accidentally closed, your work is automatically saved and can be easily recovered from the 'Recent Solutions' list.
  • Auto Sync with Connected Server: Streamline your workflow with automatic synchronization, minimizing conflicts with server content.
  • Highlighting Modified Objects: Easily identify modified objects with blue markers in the Hardware view.
  • Get Started View Update: Quickly access up to 20 of your latest solutions and benefit from updated button functionalities.
  • New Filters in Library View: Filter libraries by server version, device type, and compatibility to ensure consistency and compatibility.
  • Automatic Filter Pre-set: Enjoy automatic matching of server versions and device types for a smoother experience.
  • Promotion of Suitable Extensions: Easily find and add compatible extensions to your applications.
Introducing SEAL Template Library:
We are excited to introduce a new utility to the SEAL family. The SEAL Template Library is a comprehensive utility designed to serve as a one-stop shop for system integration templates to be used in EBO (EcoStruxure Building Operation). This utility aims to streamline the process of accessing, downloading, and utilizing integration templates, enhancing your workflow efficiency and system integration capabilities.
Key Features:
  • Library View: Displays all available templates stored on our backend, allowing users to easily download and sync these templates to their local hard drive.
  • Advanced Filtering Options: Filter templates based on communication protocols (BACnet, Modbus, Zigbee), device types (AS or RPC controllers), and server versions to ensure compatibility and optimal performance.
  • Template Sources: Templates are sourced from the global BMS applications portal and the Nordic System Integration team in Denmark, ensuring high-quality, reliable templates for various integration scenarios.
Benefits:
  • Efficiency: Significantly reduces the time and effort required to find and implement the right templates for your projects.
  • Compatibility: Advanced filtering options ensure that you can easily find templates compatible with your specific needs.
  • Quality: Access to high-quality templates from global BMS applications and the Nordic System Integration team.
Note: The new SEAL Client has been updated with links to this new forum, making it easy to find and stay connected. You can find the updated link at the bottom of the side pane, labeled "SEAL Community".
Download the updated installer from here.
We hope you enjoy the new features and enhancements in SEAL 1.12. Your feedback is invaluable to us, so please share your thoughts and experiences on the forum.
Happy designing!
  • Announcements
Replies 4
tom.pacheco
Lieutenant | EcoXpert Master tom.pacheco Lieutenant | EcoXpert Master
Posted: ‎2024-12-10 11:52 AM
2
2493
How do i get access to this client?
Benji
Posted: ‎2024-12-10 04:26 PM
In response to tom.pacheco
2477
Hi @tom.pacheco - if you provide your email address, we'll be able to give access.
@StefanLundin
EnPa
Lieutenant | EcoXpert Master EnPa Lieutenant | EcoXpert Master
Posted: ‎2024-12-29 07:14 AM
Hi @Benji I cannot access too.
Dhilly_24798
Ensign Dhilly_24798
Ensign
Posted: ‎2025-02-16 05:40 PM
In response to Benji
@Benji please provide access to dhilly.ganesh@wizardengineering.co
