How to use Spreadsheet Binder
EcoStruxure SEAL Forum
This forum is for engineers working EcoStruxure Building Operation, wanting to leverage the SEAL application to improve the efficiency in the engineering process.
  • EcoStruxure Building
  • EcoStruxure SEAL Forum
  • How to use Spreadsheet Binder
StefanLundin
Commander StefanLundin Commander
35
Benji
Administrator Benji Administrator
20
Jim.T
Lieutenant JG Jim.T Lieutenant JG
5
Back to EcoStruxure SEAL Forum
AV27
Lieutenant | EcoXpert Master AV27 Lieutenant | EcoXpert Master
Posted: ‎2025-04-15 07:15 PM
1458
Hello, i am trying to use the SEAL program and utilise the spreadsheet binder.
The ES is version 3.2.4.22 and ASPs 3.2.3.59
I have seal logged into the ES and imported the CSV file, I am unable to upload CSV files but have pasted below the format, the SEAL program says success but no binding happens?
Can anyone help on how to use this properly and is this safe to do hundreds of bindings across multiple controllers? ( obviously would take a backup first)
From To
/AS-12/Level 12/Floor Occupancy/Values/AhuHr5OptSs/Value /AS-L28-AHUs/BACnet Interface/Application/Floor Opt SS/AhuHr5OptSs_Level 12/Priority16
  • Script
  • Training
FredrikAlmgren
Lieutenant JG FredrikAlmgren Lieutenant JG
Lieutenant JG
Posted: ‎2025-04-15 11:07 PM . Last Modified: ‎2025-04-15 11:09 PM
1
1408
It seems like it won't parse your rows from the sheet. Did you check the example Excel file linked in the description?
It looks like the script wants a semicolon separator, you can open your csv file in notepad (after you saved as
CSV UTF-8 Comma delimited) and check the format.
https://schneiderelectric.sharepoint.com/:f:/r/sites/SEALCommunity/Shared%20Documents/SEAL%20Script%...
StefanLundin
Commander
Posted: ‎2025-04-15 11:39 PM
1
1403
Hi Anthony, I tried your use-case and got it to do the bind.
Your result log 'Binding using 0 entries' indicates you might have some format issue in your csv file.
The first line in csv should be a header line 'From;To'
If you click on Details on the Script card in the Library view you got an example csv file that you may download.
I've attached my csv as a zip as well.
Also , since your script need to write to a server outside the base path (to another server), ensure you have the 'Allow operations outside the confines of the base path' checked
Spreadsheet Binder.zip
Replies 6
AV27
Posted: ‎2025-04-15 07:16 PM
adding the execution and results view
FredrikAlmgren
Lieutenant JG
1
1409
StefanLundin
Commander
1
1404
AV27
Posted: ‎2025-04-16 02:50 PM
In response to StefanLundin
Hello Stefan, thank you for your help.
I did not see the CSV example in the seal program. I successfully used it to bind 102 variables instantly.
thanks again
AV27
Posted: ‎2025-04-16 02:51 PM
In response to FredrikAlmgren
Hi Fredrik i didn't see the example file, ive now got it working with great success. thanks mate
Adam_Tri-M
Janeway Adam_Tri-M
Janeway
Posted: ‎2025-10-16 01:20 PM
The semi-colon threw me for a bit too, since we use Commas in NAM. So I modified the script to allow you to pick which deliminator to use. Also fun figuring out how this stuff actual works. I see so much potential with this tool. Already have my software guru looking at it for other things!
SpreadsheetBinder-1.5.3.zip
