Data center and network security
EcoStruxure IT security
The EcoStruxure IT platform is security hardened with a mandatory two-factor authentication and high encryption standards.
  • EcoStruxure IT Help Center
  • EcoStruxure IT Security
  • EcoStruxure IT security
  • Data center and network security
  • Mark as Read
  • EcoStruxure IT Security Handbook
  • Application security
  • Product security features
  • Data privacy
  • Subprocessors and Subcontractors for EcoStruxure I...
  • TLStorm vulnerabilities
  • Log4j vulnerability CVE-2021-44228
  • OpenSSL critical vulnerability
  • EcoStruxure IT Expert ISO 27001 Certificate
  • Data privacy
EcoStruxure IT Support
Request Support
Back to EcoStruxure IT security
  • Mark as Read
Sisko JLehr Sisko
‎2023-11-14 10:59 AM
Physical security
Facilities
The EcoStruxure IT servers are hosted in the United States on the Microsoft Azure Cloud, which is ISO 27001, HIPAA, FedRAMP, SOC 1, and SOC 2 certified.
Learn more about Microsoft Azure facilities, premises and physical security
Network security
Logical Access
Access to the EcoStruxure IT Production Network is restricted by an explicit need-to-know basis, utilizes least privilege, is monitored, and is controlled by our Operations Team. Employees accessing the EcoStruxure IT Production Network are required to use multiple factors of authentication.
DDoS
As EcoStruxure IT is running on Microsoft Azure, Schneider Electric leverages their always-on traffic monitoring, and real-time mitigation of common network-level attacks, providing the same defenses utilized by Microsoft’s online services.
Third Party Security Penetration Testing
Schneider Electric continuously employs a rotating number of 3rd party certified hackers to perform detailed penetration tests of the entire EcoStruxure IT platform.
Learn more about our security test report sharing policy
Monitoring
EcoStruxure IT is maintained and operated by a core DevOps team with extremely high standards for cyber security and data privacy. All parts of the EcoStruxure IT system are continuously monitored and scanned for potential security vulnerabilities or privacy issues.
The DevOps team is on-call 24/7 and able to react promptly to newly discovered threats or issues.
Encryption
Encryption in Transit
All connections to the EcoStruxure IT cloud are validated using an industry standard 2048 bit RSA certificate and data is encrypted in transit using 256 bit AES encryption.
For Android versions prior to 7.0, Schneider Electric can only guarantee 128 bit AES encryption due to limitations in the Android platform.
Encryption at Rest
EcoStruxure IT data is encrypted using 256 bit AES encryption.
Availability and Continuity
Uptime
EcoStruxure IT maintains a publicly available system-status webpage which includes system availability details, scheduled maintenance, service incident history, and relevant security events.
Redundancy
All components of the EcoStruxure IT platform are deployed in high availability configuration to eliminate single point of failure. All data is backed up to separate storage to prevent data loss.
See also
Data privacy
Subprocessors and subcontractors for EcoStruxure IT
