what table is the external systems device total power output held in?
  • EcoStruxure IT forum
  • what table is the external systems device total power output held in?
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 06:40 PM . Last Modified: ‎2024-04-09 01:53 AM
691
(CID:105457901)
  • Data Center Operation
Replies 5
Posted: ‎2020-07-02 06:40 PM . Last Modified: ‎2024-04-09 01:52 AM
Hi Pete, Can you please add more details and possible some screen captures to illustrate what you are looking for, thanks. Kind regards
(CID:105457940)
yes, it's not very clear is it.
i'm talking about measured loads from metered power strips in the racks.
we can see values by clicking on a power strip and going to the properties.
There is an 'external systems' heading under the properties, with 'device' as a sub header. when you click on the device sub heading, you can see the realtime kw value of the power strip. I would like to extract that value out through DCO against the rack pdu details. I might have to do it via the etl engine, so would like to know where that value & field are in the DCO db.device power output.png
(CID:105458009)
Hi peter.e.morris
The realtime values are only shown in Data Center Operation, but they are not stored. If you would like to get the realtime value will you need to get it from Data Center Expert instead. I assume you are using Data Center Expert as your monitoring platform.
Instead of ETL will you need to use webservices to get the required information from Data Center Expert. You can find more information about Data Center Expert web services here
Jesper
(CID:105458016)
Posted: ‎2020-07-02 06:41 PM . Last Modified: ‎2024-04-09 01:52 AM
DCO does not show real time values, the values in the screen shot, are an average and peak (max) value of RMS power (assuming the device is reporting RMS power) over a time period of 30 days (the period is configurable). I am assuming the values comes from the DCE integration - if not the nature of the values depends on how the specific external system integration are implemented.
(CID:105458049)
Posted: ‎2020-07-02 06:41 PM . Last Modified: ‎2023-10-31 11:43 PM
