upgrade from ISX Central 6.0.1.8 to DCE 7.3.1
  • upgrade from ISX Central 6.0.1.8 to DCE 7.3.1
128
Posted: ‎2020-07-03 05:22 PM . Last Modified: ‎2024-04-08 12:14 AM
794
How can I migrate my ISX Central 6.0.1.8 with all settings to DCE 7.3.1?
(CID:122094097)
  • DCIM Support
Hi S. Heine,
You might want to contact your local tech support to verify your support contracts and get the upgrade links. The upgrade path will be a sequential upgrade so you will need to apply the upgrades in the following order:
6.0.1 -> 6.0.2 -> 6.2 -> 6.3 -> 7.0 -> 7.2.0 -> 7.2.1 -> 7.2.2 -> 7.2.4 -> 7.2.5 -> 7.2.6 -> 7.2.7 -> 7.3.1 (-> 7.4.1 -> 7.4.2 -> 7.4.3)
You can watch the upgrade progress from the server web page. Once the upgrade completes, download & install the updated client, login, make a backup, and start the next upgrade.
hope this helps,
Kind regards
(CID:122094131)
Hi S. Heine,
hope this helps,
Kind regards
(CID:122094131)
Hi sh_bpc,
In addition to the answer of Jef Faridi, I want to point out links to similar solved topics, that should help you:
With respect.
(CID:122094986)
Posted: ‎2020-07-03 05:22 PM . Last Modified: ‎2023-10-22 09:37 PM
