Posted: 2024-04-05 06:49 AM
I am seeing multiple [object Object] results in a basic query. These are returning from a recently created custom property called "Room Name" by a user. The custom property is a basic text field with no list or other features. Is this correct? I cannot seem to filter on 'contains value' or any filter for that matter.
Posted: 2024-04-25 04:30 AM
Hi Nigel,
Sharing a short update here,
It appears using 'ROOM_NAME' as custom properties causing sql query problem/errors in web-client Equipment Browser. Captured a bug report, so it can be fixed in future version(s).
As a current work-around/solution, I've suggested to add/configure a new/another custom properties (like room_name or Room_name) and then Consolidate 'ROOM_NAME' to the newly configured property.
Kind regards,
Posted: 2024-04-15 11:30 PM
Hi Nigel,
That's right, content of the configured custom properties should basically be a text.
The following article describes custom properties in ITA:
https://community.se.com/t5/Editing-properties/Custom-properties-in-ITA/ta-p/447081
As an example, I have configured custom properties like 'Status' and 'website' for a rack and a server (in my setup). Here is an illustration of what Equipment Browser would display for the selected filters (in Show Columns):
If you are seeing unexpected entries (like [object Object]), then I guess:
it might be browser related and you might want to reload the page and/or try with cleared cache,
or it might be something with the setup (that might need to be investigated).
Kind regards,
Posted: 2024-04-23 07:09 AM
Hi Nigel,
Sorry, I just noticed this.
I will contact you and open an investigation ticket.
Kind regards,
Hi Nigel,
Kind regards,
